SOURCE: My Aquaracer second hand problem
This is most likely the "battery change indicated" feature of your watch. Change the battery, and see if the problem goes away. If it does not, then it could be a problem with the stepper motor, which will require a watchmaker. Of course all of this is dependent on the assumption that your watch has a quartz movement. If it is an automatic, or mechanical you have bigger problems.
SOURCE: Reset Stopwatch Hands on CL1111 ?
Try setting the crown to position 2 - i.e. the position normally used to adjust the date. Then use the top and bottom stopwatch buttons to adjust the minute hand and 1/10th hand respectively.
SOURCE: Tag Heuer Link, stopwatch seconds hand stops 2 seconds before 12
Pull crown out to position 2 [in between unscrewed (1) and pulled all the way out (3)]. Tap Button B (bottom) to reset by step back to zero.
Incidentally, Button A works Hours register in same manner for position 2. You can similarly reset second and 1/10th with Buttons A and B, respectively, while in position 3. Cheers!
SOURCE: The red hand of my
It should reset with the first button, did it used to do this fun and recently just stopped functioning? Do all other functions on the watch work fine?
Let me know!
Thanks
Tim
SOURCE: i dropped my aquaracer watch
You need to go to a watchmaker. Sorry, I am good but not good enough to diagnose the damage without seeing the watch. In any case you can't fix yourself unless you are a watchmaker.
