Question about Tag Heuer Aquagraph CN211A wristwatch
My Tag Heuer chronograph will not reset to zero.
Posted by gipson on
Geoffrey Bird
    New Friend:
Try the following, which I discovered by accident on my Tag Professional. Pull the crown out to the first position, and then you may find that successive pushes of the upper pushbutton will move one of the chrono hands by one division, and the lower pushbutton will move a different chrono hand. Similarly if you pull the crown out to the second position, the pushbuttons will control the other chrono hands. In this way you can set each of the chrono hands to their zero positions. Hope this works for you. Geoff
Posted on Jan 20, 2011
  • 6 more comments
  • leighmcdowel Jul 29, 2011
    This fix worked a treat for me, too. Thank you geoffreyhb for taking the time to post. I am so relieved to have my beloved Tag Heuer watch back to perfect.
  • Alex Jul 09, 2013
    Aleileuia!!! By George, I think you've got it! A thousand thanks!
  • Jeremiah Gonzalez
    Jeremiah Gonzalez Jun 13, 2014
    my minutes hand will move when pressing the lower button, however my seconds hand will not return to zero and remains at the 45 second mark and will always return. any ideas?
  • Tony Parkinson
    Tony Parkinson Nov 15, 2014
    Geoffs answer is marvelleous - I have. a Kirium with a hand mis-aligned and this has sorted it now. It works on the F1 too ; obviously a standard function on TAGs . Well done Geoff.
  • Tony Parkinson
    Jeremiah - pull the crown right out to position 3 and step the B button.
  • Abhishek Gupta
    Abhishek Gupta Feb 03, 2018
    Woooo!! It worked.
  • Anonymous Aug 03, 2018
    Thank you. I was driving myself crazy by pulling the crown to the 2nd position and only being able to reset two of the four chrono dials. All four now reset to starting position and the OCD person can rest easy.
  • Thomas Bizzell
    Thomas Bizzell Feb 26, 2019
    OMG, it worked! Genius!!!!
Brent Suzuki
    New Friend:
I've got a Tag CAU1116
Pull the winder to the all the way out when the second hand reaches 0 seconds.
Then push both top (a) and bottom (b) buttons for two seconds. The long second hand will wind all the way around once.
Use the top (a) button to make the hand go clockwise around back to zero (or 12)
Use the bottom (b) button to scroll through the different faces (1/10, 30min) for the chrono
Posted on Feb 14, 2016
  • Charlie Chua
    Charlie Chua Feb 05, 2018
    Thanks. I have finally reset it to zero.
elliotjones
    New Friend:
    Problem Solver:
  • 5 Answers
Easy - unscrew the crown and pull it out as far as it will go - then hold both buttons for a few seconds until the large second hand (on a normal watch) does a full rotation. Then use the top button to move forward a second or the bottom button to move back... I've had a tag for 4 years, it keeps doing this and I keep forgetting how to reset it. NB sometimes it just doesn't do it for some unique Tag reason... good luck from www.zigzag.digital!
Posted on May 12, 2016
3 Related Answers
Anonymous
  • 3 Answers
SOURCE: Just had battery changed in my Tag chronograph.
I love these watches, don't you?
Posted on Aug 16, 2009
Anonymous
  • 22 Answers
SOURCE: my tag heuer carrera stop watch doesnt reset
Try this.
Pull the winder out fully. Then press the top right chronograph button to move the centre seconds hand on. Then push the winder back in.
on some models you should only pull the winder half way out.
good luck
Posted on Sep 23, 2010
David Tolond
  • 2501 Answers
SOURCE: I need to know how to use my cl1112 Tag Heuer
Copy "ww2.tagheuer.com/_documents/manuals/EI2246_en.pdf"" into your search engine and it will take you to a generic instruction manual for TAG watches.
This manual includes instructions for operation of your watch.
Posted on Mar 02, 2010
Tip
TAG HEUER Aquaracer quartz chronograph manual.
Follow this link and download original TAG HEUER Aquaracer quartz chronograph manual: http://www.tagheuer.com/the-collection/aquaracer/man/quartz-chronograph/index.lbl?w=CAF1110.BA0804
on Feb 09, 2010 | Watches
Tip
TAG HEUER Calibre S chronograph manual.
Follow this link and download original manual for TAG HEUER Calibre S chronograph: http://www.tagheuer.com/the-collection/aquaracer/man/calibre-s-chronograph/index.lbl?w=CAF7110.BA0803
I have a CAN1010 TAG AQUARACER CHRONOGRAPH and whe reset it the second arm doesn't reset to 0 but instead stops 2 seconds before..
This works! Loosen the bezel all the way. Pressing the bottom button, press one time the topmbottom and see how the chrononhand corrects by one second towards zero. Do it again and have it reset. Tighten the bezel. Thats it
May 13, 2011 | Tag Heuer Aquaracer Quartz Chronograph...
My tag heuer carrera stop watch doesnt reset properly, when u reset the stopwatch it goes one minute behind and doesnt reset to zero. how do i fix this. it never resets to zero and the red hands on the sub...
Try this.
good luck
Sep 23, 2010 | Tag Heuer Carrera Tachymetre CV2013.FC6206...
Tip
TAG HEUER automatic chronograph-chronometer manual.
Follow this link and download original manual for C.O.S.C. certified TAG HEUER chronograph-chronometer: http://www.tagheuer.com/the-collection/link/men/calibre-36-automatic-chronograph/index.lbl?w=CT511A.BA0564
Tip
TAG HEUER quartz chronograph manual.
Follow this link and download original manual for TAG HEUER quartz chronograph: http://www.tagheuer.com/the-collection/link/men/quartz-chronograph/index.lbl?w=CJ1110.BA0576
Good Morning, How do you zero out the hour and minutes? Also I can not zero out the minute hand. Thanks
If you go to "http://www.tagheuer.com/the-collection/aquaracer/man/quartz-chronograph/index.lbl?w=CAF1111.BA0803" you will find a link to user instructions on the right of the page.
Mar 14, 2010 | Tag Heuer 2000 Aquaracer Chronograph...
Tag Heuer Aquagraph CN211A wristwatch Logo
24,146 people viewed this question
Top Tag Heuer Watches Experts
Janelle Schoonover
Janelle Schoonover
Bruce Robin
Are you a Tag Heuer Watch Expert? Answer questions, earn points and help others
