Cut the remote wire from the radio.
install a relay in line
the relay will have 4 or 5 terminals
connect terminal 87 to battery power and fuse it at 3amps
connect terminal 86 to the remote output from the head unit
connect terminal 85 to ground
connect terminal 30 to your amp turn on wires
this allows the turn on load to run thru the relay and not directly off the radio remote output
SOURCE: Security unlock code for kenwood excelon kdc-x990
Call 1800kenwood there is a default code but you need the remote to enter it
SOURCE: cd player plays, but no sound comes out of speakers.
Look at the enwood. I bet you have the remote wire hooked to the blue wire insted of the blue/white wire. The blue wire goes dad when you play a cd as it is for a power antenna. The blue/white wire is your amp turn on.
Now, if you do not have a blue/whie and only blue, then obviously that circuit in the radio is bad in whch case your only other option s are either connecting it to an accesory fuse or using a toggle switch connected to power.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
first off the amp gets power straight from the battery. the amp is used to power the subs. the subs are suppose to be connected to the amp only( never the speakers).
for the second part you mostlikely killed the wires. you should get some one to look at it and check the wires. thee speakers might need to be re-wired
SOURCE: my kenwood excelon radio says protect what do i do
A faulty speaker wire or speaker is usually the problem. A thorough check by a professional with a multi-meter is recommended
