I have a kenwood deck, a farenheit 4 channel amp. There are 2 door speakers and 2 dash speakers. I would like to add a sub. Can I run it off the same amp?
SOURCE: audio system
#1. Remove 2 screws above speedometer. and then remove the 2 screws under the AC/heater control
#2. to get to the rear speakers you can either go through the trunk to remove the speakers or take the back seats out.
you dont usually have to remove the rear panel. the speakers slide right out from bottom.
SOURCE: Whining sound in speakers that changes with RPM.
poor line filtering along your amplifier!
place a high value capacitor in parallel with the supply input of your amplifier.
try 16v 3300uf, if your using 12volt source.
SOURCE: no sound coming from door speakers
In the yukon it has preamplify,if you disconnect stock stereo the amp is not workind unless you know how to find it. You gotta let the car-toy hook it up for you.
SOURCE: 2001 grand am se 4 door and want to put 2 12inch
The one you have will work but an aftermarket one would work better. You will get more output out of an aftermarket deck.
SOURCE: The speaker in all four doors stopped working.
if you have a premium sound system you will have a amplifier under your dash somewhere this could be a problem. if the amp dont work your head will and you wont get any sound. if its not a premium system from the manufacturer its prob a speaker ground problem since they normaly use a universal ground for all 4 speakers.
