Ways To Fix 'Boot Configuration Data File Is Missing' Error In Windows 10
Are you working with the Windows 10 and it was just yesterday. But now, while working with this device, you're unexpectedly greeted with error code 0xc0000034 which appears as a message "The Boot Configuration Data file is missing". According to Windows Tech Support Toll-Free 1-800-213-8289 engineers, the Boot Configuration Data error usually occurs while the Windows Boot Manager (Bootmgr) entry is not at all present in the Boot Configuration Data (BCD) store or it may even occur when the Boot\BCD file on the active partition is completely damaged or missing. So, at this point of time the Windows system is not in stage to perform the boot function properly.
But the good news about it is that the saved data will not be lost at all, and one can get it all back. Users are guided to have an access to a DVD or a USB stick containing Windows installation media. One can also download a utility from an official site to easily create one for you.
Steps to fix the next, 'boot configuration data file is missing' error in Windows 10
Fix 1: This method clearly is based on working with the installation purpose of the Windows Installation Media for Startup Repair phase
·Boot the system with the help of a newly created Windows Installation Media.
·Next, users are advised by Windows Technical Support professionals to select the type of language, time, currency, and keyboard/input method.
·Once the set-up process is done, simply click the Next icon.
·Now users are advised to hit the Repair button on the computer (NOT Install Windows) and opt for the Troubleshoot icon.
·Click on the Advanced option and then simply hit the Automatic Repair or Startup Repair icon to proceed further.
·When the system has accurately detected the OS, just pick up the one which is running on the PC.
·Finally, unplug the USB or even one can easily remove the DVD bootable media and boot up the device.
Fix 2: This process is purely based on rebuilding the Windows Boot Manager Store by using Bcdedit.exe tool. In case the previous method did not work out with you, just move onto this step.
·Plug-in the USB or inset the DVD with the Windows Installation Media and boot up the PC carefully.
·After that, hit a key as and when required to do so
·Set the Language, time, currency, keyboard/input method, and then hit the Next button.
·Select the Repair your PC (NOT install Windows) option next.
·Selection of the type of OS which you wish to fix is necessary. Hit the Next button.
·When the System Recovery Option is in execution phase, simply select Command Prompt icon.
·Type the required command in the Command Prompt window by simply hitting the ENTER key Fix your Windows issue by getting in touch with our Windows Customer Support Toll-Free 1-800-213-8289 expert team. We are available 24 hours 365 days in a year to assist you anytime anywhere as and when needed.
1) Pull the HD out of the 'hal.dll' corrupted HD and hook it into a computer with the SAME OS (OEM, Retail, Home, Pro, etc)
2) Find the hal.dll on your current WORKING computer with same OS
3) Copy it to the secondary HD that has the corrupted hal.dll in the same locationh and plug it back in.
Get more help from here hope this helps you.
Thanks
Michel
Resolution
1. Restart the PC. The hal.dll error could be a fluke.
2. Check for proper boot order in BIOS. You might see the hal.dll error if the boot order in BIOS is first looking at a hard drive other than your main hard drive.
Note: If you've recently changed your boot order or recently flashed your BIOS, this may be what's causing your problem.
3. Run Windows XP System Restore from a command prompt. If this doesn't work or you're receiving the hal.dll error message before you're able to complete this process, move on to the next step.
4. Repair or replace the boot.ini file. This will work if the cause of the problem is actually Windows XP's boot.ini file and not the hal.dll file, which is often times the case.
Note: If repairing the boot.ini does correct the hal.dll issue but the problem reappears after a reboot and you've recently installed Internet Explorer 8 in Windows XP, uninstall IE8. In this specific situation, IE8 could be the root cause of your hal.dll problem.
5. Write a new partition boot sector to the Windows XP system partition. If the partition boot sector has become corrupt or isn't properly configured, you may receive the hal.dll error.
6. Recover data from any bad sectors on your hard drive. If the physical part of your hard drive that stores any part of the hal.dll file has been damaged, you're likely to see errors like this.
7. Restore the hal.dll file from the Windows XP CD. If the hal.dll file is truly the cause of the problem, restoring it from the original Windows XP CD may do the trick.
8. Perform a repair installation of Windows XP. This type of installation should replace any missing or corrupt files. Continue troubleshooting if this does not resolve the issue.
9. Perform a clean installation of Windows XP. This type of installation will completely remove Windows XP from your PC and install it again from scratch.
Note: While this will almost certainly resolve any hal.dll errors, it is a time consuming process due to the fact that all of your data must be backed up and then later restored.
Important: If you can't gain access to your files to back them up, you should understand that you will lose them all if you continue with a clean installation of Windows XP.
10. Test the hard drive. If all else has failed, including the clean installation from the last step, you're most likely facing a hardware issue with your hard drive but you'll want to test it to be sure.
If the drive fails any of your tests, replace the hard drive and then complete a "new" installation of Windows XP.
