Introduction
- Step 1: Add the desired effect to the Timeline
- Step 2: Define the effect startup moment
- Step 3: Define the effect duration
- Step 4: Adjust the effect properties
Video Editor
has a lot of features to make your video stuff even far more
memorable and impressive. Adding different effects to your video is one
of those catchy things that approximates the resulting video to the
interesting and amazing work. If you are a new user you’d better learn
how to import your video and place it to the Timeline first and then
adhere to the steps of this guide to see you will succeed in applying
effects for sure.
Click the
Video Effects pane and choose the effect
you like best in the right area then drag and drop it to the Video
effects row of the Timeline:
Click the effect block and move it along the row holding the mouse
button, if the suitable moment for the effect to start is caught
release the mouse button:
Bring the mouse cursor to the effect block right border until it
looks like
. Without releasing the left mouse button stretch or narrow
the block, if the suitable moment for the effect cancellation is
caught release the mouse button:
Note: you can also define the effect duration by
clicking the Duration button which appears on the panel placed a bit
above at the moment you click the effect block.
Double click the effect block to load its properties window and
adjust them the way you like then click
OK:
Besides this , you can use other tools such as
video
converter to help you in dealing with the
related information for you.
If you have a blackberry device, you can also use a
dvd to blackberry
solve the problem easily.
I do hope you can like it , I have tested them already, they are really
very easy to use , easy
to download and install. Just have a try, I won’t let you down! Good
luck to you!
