Use a proper audio recording device with "real" microphones.
You ever see any "Making of..." features for a movie or TV show? They always have separate microphones closer to the actors so as not to catch the sound of the cameras.
Rotate the Live View switch to the LV position. Focus by pressing the shutter release button halfway. Start recording by pressing the movie-record button. Stop recording by pressing the movie-record button again.
Full details are in the "Recording and Viewing Movies" section of the manual (page 107 in my copy). If you need a manual, you may download a copy here.
"Problem with the Digital Camerasi need to know if my fujifilm finepix s1500 is still undewarranty? it only works on the letter c .anything else if will just cut off and i need a phone to call "
Where did you find this camera? Did you get a Warranty Card? Can you talk to the same people you bought it from?
You already have Movies on TDK E-HG 120 VHS tapes; All you want is to Transform the media on the tapes into another record Media or on DVD.
The following process would make possible the project
1. A DVD Recorder device would transform the movies already on one media to another media.
Note: The recorder that would be acquired should have a feed area for the VHS tapes on one hand, to be played, while on the other hand, a DVD disk area from which disk medium would be recorded.
Important Notes.
The devices required to make the process achievable includes
1. The DVD Recorder or Player alsoo known with multi perpose functionality for signal convertion capability
2. The DVD recordable disks on which to record a movies onto.
Caution
The process of recording would require selection features determinable on the recorder device else would produce movies with undesireable features
For example; VHS movies are appear in decodeable formats integral when displayed on VHS players. The caution is to select a signal conversion format suitable for movies that have to transform between recordable media.
1. A DVD disk medium has formats as design specification and on which requires consideration when attempting to transfer multi media or motion pictures.
Type of formats of decodes
NTSA standards
PAL standards
Mescem standards
NOTE;
Whenever the option is available, select NTSA or PAL for appropiate code transformation
Your DVD RECORDER DEVICE SHOULD HAVE THE OPTION TO RECORD CONSIDERING MOVIES ACROSS MEDIUM TYPES
REMEMBER;
consult professional advise before acquiring an devices and mediums
If any consultation is required, refer to user guides or manuals of the devices in question.
Consult a technical expert when the need requires it.
HD movie recording disabled: SOLVED for 2 HDRSR5's (work and home): After copying all movies to computer, "DELETE ALL" from HD view. Evidentally if you have been deleting movies using computer, the still images used for 'scene selections' remain and fill its capacity. You must be in HD view when choosing Delete All (that is, rather than just deleting all Standard movie clips)
DSC-S500 can record short movie clip with sound and you can playback it on camera and can transfer that movie clip to PC Check below jog-dial mark to set camera to record movie clip.
To playback, set camera to Playback. Need further info, let me know. Thanks.
Here the phone number 1-888-257-8899. Good luck cause the number doesn't work for me anymore, don't know why, nothing about my phone services has changed. If you reach them can you ask they why does it say it is recording a movie and at the end of the movie when you press stop, it shows up "failed to stop current recording" and when you try to finalize the movie it says "disk is empty"? Good Luck.......................
