20 Most Recent
GoVideo R6640 DVD Recorder Questions & Answers
CAN'T RECORD ON DEMAND MOVIES
panasonic dvd recorder model dmr es 15 records Comcast on Demand programs. I use it. it's an older model so you probably have to get it on eBay.
G ovideo dvr r6640
there is a ntsc/pal botton on your remote press that and it sould go back to normal if its not onthe remote try to go in the settings and it will ce in there someware
PLEASE HELP
PLEASE HELP
GO VIDEO R6640
Using Cable Box
two cords audio/out audio/in
vide/out from the cable box to the recorder video/in
Can't get it to record
if your cable box is digital it should have the yellow, white, red rca jacks in the back run those to the rear a/v input on your recorder then cycle through the input switch on the remote until you see the picture. (i have the same model i hope you have better luck with yours...i can't record on any new 4x or slower +rw disc i had mine since 2006 i should've got a sony!)
Can't set this thing up
I have the same model and it works wonderful, but you need the remote control to record. connect cable from video out on recorder to video in on you tv. at least you'll be able to play the dvd. If this doesn't work it's because you need the remote to set the date and time features.
Beocenter 1
you could also check that the regioncount hasn't been exceeded it can only be changed a certain number of times
4/18/2022 9:42:21 PM •
GoVideo...
Answered
on Apr 18, 2022
