Polaroid PhotoMax PDC 640 Digital Camera Logo
Posted on Feb 14, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Looking for a memory card where could I get one?
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 317 Answers
  • Posted on Feb 14, 2011
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
317
Questions
Helped
63111
Points
867
Most types are available from ebay
Why is my pl90 samsung digital camera saying that i have the memory card in erong when its in right
Try this. First try another memory card. This will help work out if it is a camera or a memory card issue. Remove the card and take a very close look at the metal contacts on it. Your looking for dirt or damage like scratches or missing metal.
Next using a light, look inside the slot the card fits into for loose dirt or lint.
Connect the memory card to your computer/laptop and check the card registers on there. You could also try re-formatting the card to clear it and reset it to factory level.
How do i upload music to my memory card
First we need to make sure that your MicroSD card is formatted properly. Go into settings and look for the memory settings in you phone. It should say phone memory and card memory. We want the card memory option. Select that and then look for options. It should say format card after that. Then go into wherever your music is stored and select the songs that you want to move and click move.
Mar 16, 2011 • Cell Phones
I put in new memory card it says memory full
Look through the camera's options to try and find the "memory" section. Then look for the option to format the memory card. This should clear everything off of the card. Be careful, though, if there is anything on the card you want to keep!
1helpful
How do I delete all the pictures from my memory card on my i532 Polaroid digital camera.When I delete them on the camera with the memory card in it,they are still on the memory card .
Hello. Look at the edges of the card for a small slide button and make sure the card is unlocked. Then press the menu button and look in the settings or tools for "storage"or "memory".options. What you need to find is "Format". If you do choose to Format memory card. This will permanantly remove ALL the information on the card.
builderdale
What are the slots on the front panel used for?
Those are card reader slots.
Various types of memory cards can be used.
A memory card, (Or can be stated as Flash Memory Card), takes the place of the old Floppy Disks, for one.
It is digital. There is no disk inside, just hardware electronic components.
Due to the size of trying to explain every type of memory card that is available, and the memory card itself, I would like to give you this link,
http://en.wikipedia.org/wiki/Memory_card
Here it explains the basic format of a memory card.
You can click on the titles of the memory card/s, (in blue), to get a deeper explanation, of that particular memory card.
The specifications for your eMachines ET1810 Desktop PC, state that you have the following card reader slots for,
1.Compact Flash (Type I and II)
2.CF Microdrive
3.MultiMedia Card (MMC)
4.MMCmobile
5.MMCmicro
6.Reduced-Size MultiMedia Card (RS-MMC)
7.Secure Digital Card (SD)
8.miniSD Card
9.xD-Picture Card
10.Memory Stick
11.Memory Stick PRO
12.Memory Stick PRO Duo
13.Memory Stick Micro (M2)
Look above each slot for an abbreviation.
For example on my computer,
I have one card reader slot that is approximately 1 inch wide.
It looks like a T that is stretched out.
It has SD/MMC/SM/MS/MS-PRO, above it.
This means that the card reader slot will support, (Use),
[In order as printed above],
1.SD Card - Secure Digital Card
2.MultiMedia Card.
3.Smart Media card
4.Memory Stick
5.Memory Stick Pro
I have one more card reader slot. It has CF-Microdrive above it. A wider slot than the above, and looks like a upside down stretched out T.
This means of course that it uses, (Supports), a Compact Flash Microdrive card
I've tried to explain the various card reader slots, on your computer's front panel, without being too technical, or being offensive in nature.
If you want, I can explain as technical as you wish, or simplify my solution more.
This is the Specifications page for your eMachines ET1810,
http://support.gateway.com/emachines/desktop/2009/emachines/et/et1810/ET1810sp2.shtml
Scroll down, and look to the right of the heading - Card Reader.
These are the cards your computer supports, (Uses)
Looking at the main support page for your eMachines, it looks as though you have four card reader slots.
Three grouped together on the left side, and two in the middle.
The two slots to the far right are USB ports, with probably a headphone jack port, and a microphone port to the right of them.
This page gives a little more detail, as to what your card reader slots support,
http://support.gateway.com/emachines/desktop/2009/emachines/et/et1810/ET1810fv.shtml
10helpful
Memory card protected
If your memory card is protected, remove the memory card. Look at your memory card you can see there a small push button push it so that the card will not protected. Reinsert your memory card to your camera.
Regards
PCmania
4helpful
Memory card locked
go to settings in your phone look for a button that says memory inside you will get several options depending on your phone it will normally say something like lock memory and unlock memory of course you want to unlock memory.. if this does not work pull your memory card and on the side of the memory card is a very small slider button that says lock and unlock just select unlock and your ready to go.. I hope this has been of some help at the very least it gives you an idea where to look and what to look for
best wishes okcfirewall
All of my files have gone :O
That means that the phone is not detecting the memory card.
this happens either when memory card is faulty, or when there is a problem on memory card slot contacts in phone (eg:dirt, broken contact).
Test the memory card on a computer with card reader.
If memory ccard does not work on PC, then the card is faulty, data may be lost. In that case test phone with new memory card.
If memory card is OK , try blowing into memory card slot in phone and reinsert memory card in phone after backing up your data.
If the phone does not work with more memory cards, then the phone memory card slot is defective.
Regards.
2answers
Card locked
take out the memory card
>look for a lock tab at the side of it
>push it up
>insert the memory card back.
>that should do it
*card lock is a feature of the memory card so that you won't accidentally erase the files that are saved in it
hope this helps
3helpful
2answers
Won't read memory card
i hvae had this happen many times... ok this is what you will need to do. take the memory card out and look at the little brass things and clean them with something thats cotton. repeat this till it reads. i hope this will help.
Top Polaroid Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Tom Shanks
Tom Shanks
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
