20 Most Recent
Polaroid PhotoMax Fun 320 Digital Camera Questions & Answers
I have a 320 digital my software dose not work whit win 7 is there some updates ?
Have you installed the software on the computer first?
Updates for every model camera, you only can find on the site of your own brand. Type the brand name and support and software or drivers. Watch out for other sites, because lots of sites offering drivers and software, but are not brand specific and only try to install malware on your computer.
1/15/2015 11:54:35 AM •
Polaroid...
Answered
on Jan 15, 2015
Driver for installation my polaroid
You dont need a driver software. The following microsoft link tells you step by step how to set up your camera for downloading pictures to PC.
http://www.microsoft.com/windowsxp/using/digitalphotography/takeit/transfer.mspx
10/24/2011 1:06:52 PM •
Polaroid...
Answered
on Oct 24, 2011
I need the software to install the Polaroid
I've searched the archives at Polaroid and this is no longer available. If the camera uses a memory card, all you need to do is use a card reader to download the pics to a folder you create on your desktop. Once the pics are in the folder, you can view them individually or as a slide show. You don't really need the software.
7/30/2011 6:02:24 AM •
Polaroid...
Answered
on Jul 30, 2011
I need a disc forwindows7
Your camera isn't compatible with Vista and Windows 7, there are no update programs for these camera's.
Sorry; thank you for using Fixya.
6/6/2011 4:09:21 PM •
Polaroid...
Answered
on Jun 06, 2011
Can I download 320 camera pictures onto xp
Of course.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
4/5/2011 5:39:03 PM •
Polaroid...
Answered
on Apr 05, 2011
What do i need to install Photomax with Vista?
The problem can be found where the DL for the program hasn't installed
and as a result the software reports an error. Delete the program,
fresh install in a new location and then try running it again. If it
continues to crash, check your security settings for program
installation to ensure this is not set too high thereby prohibiting the
running of the program. If you are using an illegal copy of the program
then the game is up and you will need to purchase the full program. If
you continue to have problems and you do actually own the software then
get in touch with the software company and let them assist you.
**You need either ubunthu or fedora 8
11/7/2010 6:09:03 AM •
Polaroid...
Answered
on Nov 07, 2010
I have a mac running os x version 10 and the
To get an up-to-date driver, you need to go to the Polaroid website and download and install the correct drivers, if they are available. but I have searched and not found much help, except below.
That driver you need is a TWAIN driver. It is more like a scanner driver than a Windows camera driver. No new camera will show up in the list of cameras. After you install the driver, you need to run a program like Photoshop that can do an image capture from a TWAIN device (it will be in the menu, something like file/acquire/TWAIN). Then you select the Polaroid 320 from the list of TWAIN devices, and the driver will pop up a window which displays thumbnails of all the pictures on the camera allowing you to select one. When you select one, the image will load into the application so you can edit or save it. (Photoshop seems to allow you to select multiple images, but it looks like The Gimp only lets you select one).
Below is a driver to try, it indicates that it is suitable for?
http://downloadnew.org/drivers/scanner-camera/polaroid-fun-320-twain-driver-88689.html
10/22/2010 9:56:25 AM •
Polaroid...
Answered
on Oct 22, 2010
