Question about RIM BlackBerry Bold 9000 Smartphone
I would like to know how I can make my phone ring longer? Only rings 3 times; hardly time to get to it! Thanks.
Posted by lesleypurvis on
GeorgeegroeG
    New Friend:
  • 3 Answers
This is usually a setting that your phone service provider sets. I am in Australia, and we would contact our service provider 'Telstra' and ask them to extend the ring time to 30 seconds (maximum).
Posted on Feb 16, 2011
My Samsung Jet only rings three times before going onto voicemail. Can't find how to set ot to ring longer. Thanks in advance
This is a setting that you cannot change from your handset. You will need to call your wireless provider and they can lengthen the ring time before your calls are routed to the voicemail system.
Mar 19, 2011 | Samsung Jet S8000 Cell Phone
My phone only rings 3 times then stops how can i make it ring longer thanks brian
When it stops ringing, the caller goes to your voice mail, right?
If so, then you need to contact your phone company and have them change your "Ring Cycle" -- that's the number of rings before the voice mail system picks up.
Some phone companies have a way for you to do this yourself from their website, other require that you call up the customer service line. Either way, the thing you want to adjust is your voice mail ring cycle.
Sep 27, 2010 | Doro Cell Phones
Incoming calls ring 3 times at main extension, then phone stops ringing at main & rolls over to ring at all other phones. Phone rings once at those extensions before going to voicemail. (We have...
Your voicemail thinks that it is ringing six times. The time that it takes to transfer to the extensions counts. Whiloe it seems that there is a lapse the system actually is using enough time to ring six times total. If you need longer ring time at the extension, take in account the transfer time and set it to pick up after 8 or 9 rings. It will actually only ring six. You just have to trick the system a little.
Jul 22, 2009 | Cell Phones
Phone doesn't ring long enough
Apparently the problem was at the networks end. I had to ring them to set the ring to a longer time and had them deactivate voiemail.
Feb 07, 2009 | LG KU990 Viewty
Ring 3 times then goes to Voicemail
Does the phone actually ring 3 times. I was having the same problem I was informed that it was not even going to my phone. When I had this same problem T_Mobile could not fix the problem using the 3 g network. If you shut off the 3g feature your problem will go away
Jan 12, 2009 | HTC G1
I want my N73 to ring for longer than 2 rings
Hi
Set a FULL SONG from your archive as RING TONE. This will play longer time to remind you that someone is calling.
Thanks.
Supriyo DG
Jun 12, 2008 | Nokia N73 Cellular Phone
How do i get my prada phone to ring more that just 3 times
u need to cancel all your diverts on ur calls and tha should sort it out for you
Jan 14, 2008 | LG Prada KE850 Cellular Phone
Lengthen my ring time
hello you need to go into your settings then click on divert, it will say your settings are on divert:if unavailable thats why your phone call cuts off if you havent answerd it in a certain amount of time. So just turn divert off completely and your fone will ring longer
Jan 02, 2008 | Motorola Mobility RAZR V3
RIM BlackBerry Bold 9000 Smartphone Logo
170 people viewed this question
Top RIM Cell Phones Experts
Ekse
William Norris
William Norris
Muntejaya Ginting
Muntejaya Ginting
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
