Jabra BT2080 Bluetooth Headset Logo
Posted on Feb 12, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cannot get my phone to recognize the device. need steps 1,2,3
Joe Negus
Level 2:
President:
  • Expert 652 Answers
  • Posted on Feb 12, 2011
Joe Negus
Expert
Level 2:
President:
Answers
652
Questions
Helped
165822
Points
154
Here is the link pages 4and5 (http://img9.jabra.com/sites/Jabra/GNimages/Products/WirelessHeadset/BT2070/BT2080_UM_6909.pdf)
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 09, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
663
Points
Unpaired my head set now i can re-pair it
When i plug my iphone 4s into my pc with itunes running it doesnt recognize the phone, cable is good pc makes sound when i plug in
There are several methods you can try to fix this issue. One of them shows below.
How to Fix iTunes Not Recognizing iPhone in Windows 10 Before You Begin:
  • Make sure that you have the button Trust this computer on your iPhone when connecting to your PC.
  • Make sure that you have installed all Windows updates. This is to make sure that your computer device drivers are up to date.
  • Make sure your iPhone USB cable works well.
  • Make sure your iOS device is turned on.
  • Make sure you have the latest version of iTunes installed.
  • Now, the following solution may help you fix the iTunes issue if you found that your iTunes does not recognize iPhone in Windows 10 computer.
    Step 1. Connect your iPhone to computer and wait for some time until the device is recognised.
    Step 2. Right-click "Computer", Go to "Device Manager". Then expand category "Universal Serial Bus controllers" and locate "Apple Mobile Device USB Driver".
    Step 3. Right-click "Apple Mobile Device USB Driver" and click "Update Driver Software". On the pop-out window, choose "Browse my computer for driver software".
    Step 4. Then choose "Let me pick from a list of device drivers on my computer".
    Step 5. Click "Have Disk..." button.
    Step 6. Click "Browse".
    Step 7. Navigate to "C:\Program Files\Common Files\Apple\Mobile Device Support\Drivers". Then double-click the usbaapl file. If you have a 64-bit version of Windows, this file will be called usbaapl64.
    If you don't see usbaapl64 here or if there isn't a Drivers folder, look in "C:\Program Files (x86)\Common Files\Apple\Mobile Device Support\Drivers".
    Then you need to install the driver for your Windows 10. After installing, unplug your iPhone, then reconnect it using USB cable. Open your iTunes and see if your iPhone can be detected or recognized by iTunes.
    For more details, check: How to Fix iTunes Not Recognizing iPhone in Windows 10
    I have forgotten my iphone 5 screen lock code?
    Unfortunately, there is no way around your passcode on the lock screen. This for your protection. However, your phone is NOT useless and you CAN get into it but you must wipe the device completely and none of your information will remain once this has been done. If you've exhausted all passcode variations and still can't get in, do the following steps to wipe the device:
    1.) Plug your phone into your computer.
    2.) Open iTunes on your computer (It may open automatically)
    3.) CLICK AND HOLD BOTH HOME (Bottom) & POWER (Top) BUTTON until the device shuts off. When it shuts off, release the power button and continue holding the home button until iTunes recognizes the device again.
    4.) iTunes will recognize the device as being in DFU mode and will give you the option to Restore the device which again will WIPE everything on the phone. Just click Restore to begin the process.
    5.) When this step is complete you will regain access to your device.
    *TIP* If you have your phone backed up on iCloud or iTunes you can restore a previous back up file and can regain some of your information.
    I NEED MY Iphone 4 unlocked UNLOCKED
    Wireless Optical Mouse Mi-4150K doesn't connect to pc
    windows 7/vista :
    -step 1 :Press the windows button (start button).
    -step 2 : In the search bar type device manager.
    -step 3 : Open the device manager.
    windows xp/2000 :
    -option 1 for opening the device manager :
    -step 1 : Press the windows button (start button).
    -step 2 : Open the control panel.
    -step 3 : Open the "System properties".
    -step 4 : Click on the hardware tab.
    -step 5 : Click device manager.
    -Option 2 for opening the device manager :
    -step 1 : Press the windows button (start button). -step 2 : Select "Run"
    -step 3 : Type the following into the text box "devmgmt.msc"
    -using the device manager :
    -step 1 : Once the device manager is open, click on "Mice and other pointing devices" or "other devices" (if prompt).
    -step 2 : In the newly open menu, if there is a "?"right click on it and press update driver.
    This should almost force the computer to recognize the hardware plugged into the USB port.
    Hope this helped!
    2answers
    Backup samsung convoy contacts to pc
    Because of the importance of transferring contact information from one communication vehicle to another, there are a number of different automated ways to transfer contact information. To import contacts, such as VCF files from computer to Samsung Galaxy S9/S8/S7/S6/S6 Edge, you need to ask help from an Android data transferring program named MobiKin Assistant for Android or Assistant for Android (Mac Version). With it, you can move contacts between your Samsung Android phone and computer in 1 click.
    Step 1. Click the above button to download and install MobiKin Assistant for Android on your Windows or Mac computer according to its prompt instructions. Then, launch it directly. After that, you'll be required to connect your Android phone to computer with USB cable or WiFi. Just choose the method for connecting as you like.
    Step 2. After connection, you need to do some operations to make the device be recognized by the program. For example, you need to open USB debugging under "Developer" option, and install a right USB driver on the PC. (Sometimes you may need to install the USB driver manually due to unknown reasons when the automatic operation is not working well.)
    Step 3. When your Android is recognized by the Android Assistant software, you can see an interface like below. Now, directly click "Super Toolkit" in the top menu, and select "Backup" option.
    Step 4. Check the device and click "Contacts", then specify an output folder according to your needs. After that, click "Back Up" button to begin the process. backup-android-files-uwkecbqhxdnurjdgs33nmwp2-4-2.jpg
    Complete procedure can be found on below link: 5 Ways How to Backup Android Contacts
    Learn More:
    How to Import Contacts to Samsung Galaxy S9 S8 S7 S6 Edge
    Bluetooth in car not recognizing Droid 2 any more - worked fine but now does not
    your limit would have crossed
    there are a particular no of devices that could be paired
    Pair your Verizon Motorola Droid 2 smartphone with a Bluetooth device using these steps:
    1. From the Home screen tap Menu > Settings app.
    2. Tap Wireless & networks.
    3. Tap Bluetooth settings.
    4. Ensure that Bluetooth is checked.
    5. Turn the Bluetooth device on and set it to discoverable if required.
    6. Tap Scan for devices.
    7. The Droid 2 should locate any devices in the area. You may need to enter a password. Most devices have a password of 0000 (four zeros).
    The Bluetooth indicator should now show in the notification area. This indicates you are paired successfully.
    4answers
    ITUNES DOES NOT SEE MY IPHONE
    the same exact thing happen to me......then I purchased a new connector (I used the old usb so much with the ipod)...and bingo itunes recognized the iphone......
    IPhone not recognized by pc, in recovery mode
    Method 1. Manually Update the Apple Mobile Device USB Driver
    Step 4. Choose "Let me pick from a list of device drivers on my computer" and click "Next".
    Step 5. On "Update Driver Software - Apple Mobile Device USB Driver" box, click "Have disk". However, if this button is not available on this box; click a device category like "Mobile Phone" or "Storage Device" in case if that is what you see.
    Step 7. Navigate to "C:\Program Files\Common Files\Apple\Mobile Device Support\Drivers". Then double-click the usbaapl file. If you have a 64-bit version of Windows, this file will be called usbaapl64. If you don't see usbaapl64 here or if there isn't a Drivers folder, look in "C:\Program Files (x86)\Common Files\Apple\Mobile Device Support\Drivers".
    Step 8. On the "Install Disk" window, click "OK".
    Step 9. Click "Next" and after this, Windows will assist you with the driver update.
    Now, you are ready to go. Open iTunes to check if it recognizes your iPhone
    If this method won't work, check this guide for more methods. How to Fix iPhone Not Recognized by Windows
    1helpful
    The desktop manager will not recognize my blackberry is plugged in and I cant get past the JVM error 102 message
    following Error message appear when one of your .cod files are corrupted on the Blackberry smartphone....
    To resolve this Issue you need to reload Blackberry Device Software
    Befrore performing these steps take a backup of your Device Data.
    Reload to Blackberry Device Software
    Steps ;-
    1.Connect Blackberry device to your Computer and open Blackberry Desktop Manager.
    2. Double Click on Application Loader
    3.Click Next to start the installation process.
    4.Type your Blackberry smartphone password,if prompted and Click Ok.
    5.Select the check boxes next to the names of the applications to be loaded,and then click Next.
    6.Click Ok> NEXT>FINISH
    After putting the headset into pairing mode, my phone (also an LG) will not recognize and pair with headset. Also tried another (non LG device) and that would not pair either? Headset used to work with...
    According to a VzWireless Tech, take the battery out for 30 seconds and then put it back in. The phone should reset itself to pair the bluetooth headset with the phone. If that does't work remove the device from the phone and start from step 1. I removed the device from the phone then I took the battery out for 30 seconds. Then I paired the bluetooth and followed the next steps to complete the sync.
    Top Jabra Radio Communications Experts
    Grand Canyon Tech
    Grand Canyon Tech
    ExpressFiX
    ExpressFiX
    ZJ Limited
    ZJ Limited
    Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
