Question about Apple iPhone Smartphone
IPhone not recognized by pc, in recovery mode
IPhone 3G is in recovery mode, power button doesn't work, and when i plug it in to my computer its not recognized! What should i do?
Posted by dfender2022 on
Michael Lei
    Master:
  • Apple Master
  • 498 Answers
Method 1. Manually Update the Apple Mobile Device USB Driver
Step 1. Connect your iPhone to computer and wait for some time until the device is recognised.
Step 2. Right-click "Computer", Go to "Device Manager". Then expand category "Universal Serial Bus controllers" and locate "Apple Mobile Device USB Driver".
Step 3. Right-click "Apple Mobile Device USB Driver" and click "Update Driver Software". On the pop-out window, choose "Browse my computer for driver software".
Step 4. Choose "Let me pick from a list of device drivers on my computer" and click "Next".
Step 5. On "Update Driver Software - Apple Mobile Device USB Driver" box, click "Have disk". However, if this button is not available on this box; click a device category like "Mobile Phone" or "Storage Device" in case if that is what you see.
Step 6. Click "Browse".
Step 7. Navigate to "C:\Program Files\Common Files\Apple\Mobile Device Support\Drivers". Then double-click the usbaapl file. If you have a 64-bit version of Windows, this file will be called usbaapl64. If you don't see usbaapl64 here or if there isn't a Drivers folder, look in "C:\Program Files (x86)\Common Files\Apple\Mobile Device Support\Drivers".
Step 8. On the "Install Disk" window, click "OK".
Step 9. Click "Next" and after this, Windows will assist you with the driver update.
Now, you are ready to go. Open iTunes to check if it recognizes your iPhone
If this method won't work, check this guide for more methods. How to Fix iPhone Not Recognized by Windows
Posted on Jun 25, 2019
4 Related Answers
Anonymous
  • 30 Answers
SOURCE: GPS not working
Try this -
1) Settings > Enable 3G Change to Off.
2) Use the iPhone GPS receiver to locate your position
3) Settings > Enable 3G change to On.
There are two positioning systems in the iPhone 3G, one is the 3G network, and the second is the GPS receiver. The problem occurs when the data from the two systems doesn't match.
Posted on Jul 31, 2008
Anonymous
  • 6 Answers
SOURCE: iPhone 3g activesync
Your iphone can not be synced with activesync, it must be synced with itunes! I've tired and can not get it to work! only itunes!
Posted on Aug 01, 2008
Anonymous
SOURCE: iPhone 3G Error 0xE8000001
I just had this problem and it turned out to be... It didn't like my iPod cable. Switched to the iPhone cable and it worked.
Seems to be an iPhone 2.0 prob, or 3g prob, since I was using the iPod cable to sync my old iPhone just fine.
Posted on Aug 07, 2008
Joed911
JDTec
  • 4338 Answers
SOURCE: My Iphone 3g 8gig is stuck on the Apple logo
Try each of the following resets:
Download the latest iTunes to your computer and reset the iPhone. Then re-sync it.
Reset
To reset iPhone, press and hold the Sleep/Wake button and the Home button at the same time for at least 10 seconds. During this time, a red "power off" slider may appear and the screen may go black, but do not release Sleep/Wake and Home buttons until the Apple logo appears.
If iPhone won't turn on, or the display freezes or doesn't respond
  1. Press and hold the Home button for at least six seconds, until the application you were using quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a few seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Jul 24, 2009
My iphone 3g 16gb is disabled connect to itunes,how do i fix my iphone
Download this software: http://cache.firmwareumbrella.com/downloads/tinyumbrella-5.00.09.exe Plug your phone in, and when TinyUmbrella recognizes it, click "Fix Recovery" and your phone will be kicked out of Recovery Mode, which is where you are stuck right now.
If that doesn't work, you'll have to plug it into your computer, and Restore it with iTunes.
Aug 07, 2011 | Apple iPhone 3G
Tip
How to restore a troublesome iPhone 3G!
If you have an iPhone 3G that is causing you problems or errors when you are trying to restore then hopefully this information can be useful to you.
If you are struggling to get your computer or iTunes to recognize your iPhone then put the device into recovery mode. To put the device into recovery mode, plug the iPhone into your computer, open iTunes, then hold the sleep button and the home button together for ten seconds before releasing the sleep button. Contine to hold the home button until iTunes pops up and tells you that a device has been detected that needs restoring.
Click restore and iTunes will download and restore the latest firmware to your device for you. Once the restore completes you can set up a new phone or restore al settings from a backup of a previous phone.
If after restoring you get an error message and your iPhone displays a plug into computer logo then we must go through some more steps to get your iPhone going.
This section is for users of 32 bit Windows, which is the majority of people. Download the iRecovery and libusb-32 package and install the libusb-32 file. Move the irecovery.exe file to C:irecoveryirecovery.exe
From your start menu go to Run and type cmd. Press enter and you will be presented with a black box with a command prompt. At the command prompt type C:irecoveryirecovery.exe -s and press enter.
Once your iPhone has been found you will have another command prompt. Now type the following commands:
setenv auto-boot true
saveenv
exit
Once again reboot your iPhone, holding sleep button and power button until the Apple logo displays, this time your phone should boot up into the normal iPhone interface.
With a bit of luck you have just restored your iPhone 3G!
on Aug 07, 2010 | Apple iPhone 3G
My iphone is hanged its shows apple logo only, hw can i solved this problem without loosing my all data,like my videos,contacts,pictures,pls help me out
Try pressing and holding both the POWER & the HOME button at the same time for around 3 to 10 seconds until it turns OFF. Then turn it back on again.
If it still won't go past the Apple logo, use tinyumbrella to Fix Recovery or to Exit out of Recovery. Download tinyumbrella using the links below: for Mac for PC (Windows)
Update tinyumbrella first if it tells you that there's newer version available.
NOTE: Your computer must be able to recognize your iPhone before you can use tinyumbrella to fix it. If your computer could not recognize your iPhone, you first need to put it to DFU mode. To learn more about DFU mode, CLICK HERE.
If those things still don't work, you'll have no other choice but to restore. Again, your computer must be able to recognize your iPhone before you can restore it using iTunes. Put it to DFU mode if your computer won't recognize it.
Read more tips for iPhone, iPad and iPod touch, CLICK HERE.
Apr 25, 2011 | Apple iPhone 3G
Iphone 3g stuck in "recovery mode" (black screen
To reset your iPhone settings,
picexporterror From the home screen, Tap Settings > General > Reset > Reset All Settings.
Still having problems?
Try deleting all the existing settings.
Note: The step given below will delete all the data on your iPhone. It will also give a reset to your settings.
From the home screen, Tap Settings > General > Reset > Erase All Contents and Settings.
Or:
  1. Press and hold the Home button for at least ten seconds, until the application you were using quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for 10 seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
Let me know if this helps or not, there are other resets available :
If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 19, 2011 | Apple iPhone 3G
Iphone wont reboot or go into recovery mode, itune doesnt recognize it cant jailbreak it all it does is turn on an off an it does that in weird cycles? any help would be great i have a 3G 4.2.1 an it was...
turn it off then plug it into your computer but as you put the 30-pin usb connector into the bottom of the phone hold the home button simultaneously. That should allow it to open in itunes in recovery mode!
Good luck, hope it all works out!
Dec 18, 2010 | Apple iPhone 3G
I replaced the screen on my cracked iPhone 3G. The phone turned on and worked fine, but the home button was unresponsive. So i took the screen/LCD out to check the connections. The phone turned back on and...
put it on DFU mode. then, try to restore it using iTunes.
I believe that you have a problem w/the home button. maybe it's pressed all the time, so the phone cannot boot.
try dismatling the screen again, and check the home button contacts.
if you think the contacts are not ok, try to replace the home button.
if yo thinks there's no problem with the home buttons, try to enter to DFU mode:
1. turn off and connect the iphone to the USB.
2. press and hold power button for 5 sec
3. press and hold power and home button for 10 sec
4. leave the home button pressed until the computer recognize the iphone as a DFU device.
5. restore with iTunes.
Cheers,
Gery
if you don
Dec 27, 2009 | Apple iPhone 3G
IPhone 3G Unknown Error Occurred 6 can't resotore to 3.0 help
turn the iPhone off, connect the cable to the computer, but do not connect to the iphone. Hold the home button and connect the iPhone to the computer. iTunes will recognize it in recovery mode. (You must have ipsw file) Hold shift and click restore. now look for the ipsw file, choose that file, and itunes will do the rest.
Aug 08, 2009 | Apple iPhone 3G
My iphone is stuck on the screen where the apple is displayed
NOTE: You need to be plugged up to your computer for this to work
1. Hold down the POWER and HOME buttons untils your phone reboots.
2. Hold POWER button until the iPhone powers OFF
3. Hold POWER and HOME buttons, iPhone will now power on.
4. When you see the apple2.gif logo, release the POWER button but keep holding the home button.
5. iTunes should alert you now saying that it has found an iPhone in recovery mode, proceed to recover as normal now.
Also the iPhone screen may go white after doing this until restored, this is normal, it's not broken.
Jul 06, 2009 | Apple iPhone 3G
Iphone will not restore
Try restoring in DFU mode, which is different than recovery mode. I happened to stumble across it while trying to restore an iPhone 3G that a user unplugged in the middle of the 3.1 update. It kept showing an error of 1611 or 13 and wouldn't restore in recovery mode. I found this DFU mode option and the restore worked fine. The DFU mode keeps the iPhone OS from loading, so you don't run into as many compatibility problems. Go into DFU mode, then try restoring the phone and see if that works.
http://techierambles.blogspot.com/2009/09/restore-iphone-with-error-13-or-1611-in.html
To enter DFU mode:
1. Connect your iPhone to your computer
2 . Turn iPhone off. You may have to hold the power and home buttons down together to force the phone off
3. Once the phone is off, hold the power and home buttons together for 10 seconds exactly
4. After 10 seconds, release the power button but keep holding home until the computer recognizes that a USB device was plugged in
5. iTunes should detect your iPhone correctly, and also allow you to restore to the factory default settings
Mar 02, 2008 | Apple iPhone Smartphone
Unlock iphone
Yeah, just plug in the iPhone and restore it to factory settings. Pretty straight forward.
If you can't get iTunes to recognize it, then you might have to use recovery mode.  Plug in the iPhone to the computer. Press and hold power button and home button until the iPhone powers off.  Once this occurs, wait 5 seconds exactly!!! Then release the power button but keep holding onto the home button.  iTunes should recognize the phone being in recovery mode.
From there, click restore and you're done.
Nov 19, 2007 | Apple iPhone Smartphone
Apple iPhone Smartphone Logo
370 people viewed this question
Top Apple Cell Phones Experts
Ekse
Marvin
Marvin
sandyp4ever
sandyp4ever
Level 1 Expert
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
