iiyama Pro Lite (White) 15" LCD Monitor Logo
Posted on Feb 04, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My menu box off my screen keeps popping up but changing nothing. i cant click on the buttons of my screen. It just pops up every second, this is very annoying! help!!
Samir Shah
Level 2:
Champion:
  • Expert 220 Answers
  • Posted on Feb 04, 2011
Samir  Shah
Expert
Level 2:
Champion:
Answers
220
Questions
Helped
127584
Points
356
The menu switch needs to be replaced.
This needs technical repair skills.
Samir
1helpful
Menu Keeps Popping Up
There is either a short in the menu button on the TV or it is sticking/dirty.
2answers
CAN YOU PLEASE HELP FIGURE OUT WHY MY VIEW SONIC 20INCH LCD MONITOR MENU BOX KEEPS POPPING UP AND IT IS DRIVING ME CRAZY
The problem is caused by either its main controller board or button controller board.
Well, I will try to change button board first, because it's cheap.
If you have never open up the LCD monitor, please don't open it up and try to fix!
Either you will damage the monitor when you open and/or be shocked by high voltage electricity!!
Menu from Projector keeps popping up. it will clear away when we click MENU button but then within 5 seconds, it will pop up again. we are using ACER XD1150 DLP PROJECTOR. would appreciate any...
hi,
Check is the remote transmits signals for menu at any time.
to check this after clearing the menu remove the battery of the remote. if the menu didn't po pup again , the remote need cleaning .
If the menu pop up again then, you have to check the menu button (push button) on your projector.
ok
2answers
How can i change my display settings on my inspirion mini i cant change my screen resolution
Just right click on a BLANK area of screen and select the graphic properities from there
depending on the operating syetem vista and windows 7 will actually offer you the "change resolution" option near the bottom of the pop up when you do that.
Menu Screen Keeps Coming up on the screen
The most commom causes are One. There ia a stuck button on the tv itself. The Menu button. The membrane switch or the TACT switch is bad and needs to be replaced. The Main bd can also be bad.
3helpful
Black Bars each side of my new monitor wide screen
Right Click on an open spot on your desktop.
If your Operating System is Windows XP, choose Properties from the menu box that pops up when you right click.
A new window will open up. Click the Settings tab at the top right.
On this menu you should see a slider bar near the bottom left under "Screen Resolution". Left Click and hold the mouse button on the grey button and move it on the slider bar over to the right one spot. Then click the Apply button on the bottom right of the box. The screen may flicker for a second and your desktop will change size. If the screen covers the whole monitor and the black bars are gone, that may be the correct resolution. Click OK on the box that has a timer and is asking if you want to keep the screen that size. If the screen does not look correct, click No and you may need to slide the button one more spot over and try the next resolution and Apply until it looks correct.
Under the slider bar as you move it over a line at a time will be 2 numbers like this 1024 X 800, and when you move the bar over the numbers will change. I believe the optimal resolution setting numbers for the 20" monitor you have should be 1680 X 1050 for the widescreen. You may want to try that setting. If it looks too small, try sliding the bar to the left and try each resolution setting.
Here's a screetshot of what the Box with the slider bar looks like: http://technophobik.co.uk/vxp_control_panel/f007_settings.asp
If you have Windows Vista, (it is similiar to XP):
Click the Start Button and click Control Panel in the Start Menu
Click Appearance and Personalization in the new window that opens up.
Click Personalization, then click Display Settings at the bottom
A new box will pop up with the grey button on a slider bar near the bottom left under "Resolution" Slide the button to the right to the next line one spot over on the slider bar and then click the Apply button. The screen may flicker and change the size of your desktop. Click OK if the screen looks correct or click No if it doesn't look correct and try sliding the button over one more line.
1helpful
LCD Main MEnu
hi,
It is possible that menu button on the monitor is stuck. I suggest to call your computer manufacturer where you purchased the monitor, check for the warranty and request for a replacement.
Keep me posted.
Thanks
1helpful
2answers
Menu screen
It could be dirt/dust has accumulated behind the buttons causing a false contact so it looks like a ghost is operating your tv making things appear and disappear.If this isn not the problem then there is a faulty component on the board where the buttons are located. If you are able to do the cleaning of the buttons yourself use a cleaner that de-greases as wel and make sure everything is bone dry before re-assembly. If not find a competant technician. Hope this helps.
2answers
Resolution notice keeps popping up every thirty seconds or so. very annoying. this happens only when using cd rom game diablo. wants me to change to 1280x1024, which my computer is set at now. otherwise...
When you load the splash screen of Diablo enter into settings. Make sure you have the game set to the screen resolution you want.
For the system. Open display properties. Click Settings, click Advanced, click Monitor. (Most games require 60 hertz) to run correctly. Change your monitor to 60 hertz. Than click the Adapter tab. Click list all modes. Move the slide bar to your normal screen res with 60 hertz. Click ok at every screen as you back out od display properties. That should stop your game from popping up.
Menu and OSD Problem
Yep. Sounds like one of the buttons is shorting out and causing the icon to pop up. You can try canned air. If your good with tools, See if you can take the bezal(the plastic part around the screen) apart to clean the button contacts.
Top iiyama Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an iiyama Computer and Internet Expert? Answer questions, earn points and help others
