Question about Acer XD1150 DLP Projector
Menu from Projector keeps popping up. it will clear away when we click MENU button but then within 5 seconds, it will pop up again. we are using ACER XD1150 DLP PROJECTOR. would appreciate any solution. thanks
Posted by tinamahadi on
  • Anonymous Mar 25, 2014
    computer wont read projector. Is something wrong with driver?. no plug and play
Electro Med Services
  • Acer Master
  • 6,694 Answers
Check is the remote transmits signals for menu at any time.
to check this after clearing the menu remove the battery of the remote. if the menu didn't po pup again , the remote need cleaning .
If the menu pop up again then, you have to check the menu button (push button) on your projector.
ok
Posted on Feb 21, 2011
Reset lamp timer lg projector model BX-401C
Try this, it works on older LG TV models:
Put the projector on. While holding down the Menu key on the projector, press and hold down the Menu button on the remote. Keep both buttons pressed for a count of at least 5 seconds.
When the Service Menu pops up, release the Menu button on the remote control first and then the one on the projector after.
Now you're in to the service menu, you need to find out which button on the remote brings up the Lamp Timer Reset function. This is where you're going to have to do a bit of trial and error. With the TVs, the remote button was the Mute key. There isn't a Mute key on the projector remote, so try the Lamp key first. If that doesn't work then try some other buttons. Here's the method.
While holding down the Enter/OK on the projector, press and hold the Lamp key for five second. If this works then the lamp timer reset box should appear. Release the remote button first, followed by the unit button.
Press Enter/OK on the remote to reset the lamp timer. If there's an On Screen Prompt to confirm, press Enter again.
Press Exit on the remote to come out of the menus.
Warning: Don't reset or change any other functions. The service menu isn't the place to be tinkering around with stuff you don't understand.
Aug 31, 2014 | Office Equipment & Supplies
Reset lamp timer
Aug 31, 2014 | LG Office Equipment & Supplies
HOW TO RESET LAMP HOUR OF LG PROJECTOR MODEL BX-401C
Sanyotv com
Sanyo TV Service Menu Method 1
1.Unplug the power cable.
2.Press and hold the {MUTE} button on the remote control while plugging the power cable back into the outlet.
3.Keep pressing the {MUTE} button until the TV powers on with the Service Menu displayed.
4.Use the {CH+} {CH-} buttons to select menus.
5.Use the {VOL+} {VOL -} buttons to change settings.
6.Some menus might have sub-addresses. Use the numeric buttons {0} to {7} to adjust sub-item data.
7.Press the {MENU} button or turn the TV off to exit.
Sanyo TV Service Menu Method 2
2.Press and hold the {VOL -} button on the TV while plugging the power cable back into the outlet.
3.Keep pressing the {VOL -} button until the TV powers on with the Service Menu displayed.
Sanyo Projector Service Menu Method 1
Factory Menu Access
1.Press and hold the {SELECT} and {INPUT} buttons on the Projector at the same time for about 10 seconds.
2.The Factory Menu will be displayed.
Service Menu Access
1.Press and hold the {MENU} and {INPUT} buttons on the Projector at the same time for about 10 seconds.
2.The Service Menu will be displayed.
Use the {UP} {DOWN} {LEFT} {RIGHT} buttons to move through menus and change values.
To exit, turn the Projector Off.
Sanyo Projector Service Menu Method 2
1.Press & hold the {MENU} button on the Projector for about 10 seconds.
3.Use the {UP} {DOWN} {LEFT} {RIGHT} buttons to move through menus and change values.
4.To exit, turn the Projector Off.
Jul 20, 2013 | Televison & Video
"clean and reset filter" alert is displayed even
You can reset the "Filter Time" on your projector and it will clear this error out of the system.
1) Clean Filter
2) Turn the power on
3) Hit the Menu button
4) Once the menu appears choose "Options"
5) Choose "Filter Time"
7) While the time is displayed hold the "Reset" button on the remote for 3 seconds
8) The "Reset" menu will pop-up and choose reset.
That should take care of it.
Mar 14, 2011 | ViewSonic PJ501 Multimedia Projector
Projector menu keeps popping up after Directv box change
Is the projector menu that comes on the menu that tells you the projector is not receiving an input signal?
Dec 18, 2009 | Refrigerators
RCA 52" Menu Keeps Popping Up and Down
I see this alot at the shop ... the front panel buttons have become damaged. THe best coarse of action is to replace the front button cuircit board assembly... **** there is a tempery fix untill you get the part... remove the front panel and take button cuicit board out...just use remote to control the tv. This is also a way to test to see if this is the problem.. if you romove the connector to the buttons and the problem goes away then the buttons are the problem. you get get this cuicit board at union electronics. You have to get the extended model number off the back ussally d52w20yx1 or yx2 or yxsomething...not to difficult a repair
Nov 06, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Menu keeps popping up!
I had this same problem with the Main Menu coming up on my Dell Monitor E171FPb and I thought I would tell you what I did to fix the problem.
1. I shut down the PC.
2. I removed the power cable and video cable from the back of the monitor.
3. I removed the four screws that hold the stand for the monitor and slid the stand off.
4. I then removed the 5 screws that hold the back cover on the monitor.
5. I took two flat blade screw drivers and carefully removed the back cover.
At the bottom of the monitor case, there is a small circuit board the holds the 6 switches for controlling the display.
6. I located the button that calls up the Main Menu. It is the second switch from the left as you are looking at the monitor from the rear.
7. I used a small solder iron and heated up the four prongs in sequence while holding the switch with a pair of needle nose pliers. I had to rotate this process from one prong to the other while all the time applying slight pulling pressure on the switch pulling it away from the circuit board.
8. Once the switch was removed, I put the cover back on and tightened up the five screws.
9. Then I slid the base back in the slot it came from and tightened the four screws.
10. I connected the video and power cable and turned on the PC.
With the switch removed the Main Menu never popped up again and I am so very happy.
May 25, 2008 | Philips 42PF9431D/37 TV
Resetting the air filter timer
Hiya there, just worked out how to reset the filter timer so for those that need to know here's the solution;
Bring up the menu and go right the way down to "Option" where it shows you the lamp and filter hours.
Next highlight/select the filter timer section and while its on there hold the RESET button on the remote for 5 seconds.. this then pops up with a resert option and hey, 0h again, good as new! :-)
Oh and if you dont have a remote, just hold the right arrow button instead for 5 seconds in place of the reset and follow instructions as above!
Hope this helps.
Regards,
Omar.
Dec 12, 2007 | Hitachi Office Equipment & Supplies
Problem on hp monitor
I know you said there were others that had the same problem with the Main Menu coming up and I thought I would tell you what I did to fix the problem.
Oct 12, 2007 | HP Pavilion F1523 15" LCD Monitor
Acer XD1150 DLP Projector Logo
316 people viewed this question
Top Acer Office Equipment & Supplies Experts
Richard C Cohen
Richard C Cohen
Marvin
Marvin
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you an Acer Office Equipment and Supply Expert? Answer questions, earn points and help others
