20 Most Recent Vizio 60" E601I-A3 Full HD LED-LCD TV Questions & Answers
2answers
What are the symptoms of a Vizio e601i-A3 main board that has gone bad?
You are correct. You can get replacement parts here: TV Parts Universal TV Stands DLP Chips ShopJimmy
9/16/2019 12:51:45 AM • Vizio 60"... • Answered on Sep 16, 2019
2answers
I replaced the T-con board on my Vizio TV, but I still don't have any picture, just sound. What else could it be?
Think something may have gotten unhooked when you put everything bacK together? Check out all connections and ribbons between boards for proper contact.
3/13/2018 1:44:27 AM • Vizio 60"... • Answered on Mar 13, 2018
Power shuts off by itself....
Actually I don't think this is a power supply issue, the problem is in the main board, test the 13 volt rail on the main board that feeds the audio section of the set , there will be a star that identifies the various test points on the boards, look for the one that has 13 volt by it, if I remember right its at the bottom left side of the main board, I think you will find it starts out at about 8 volts then drops off as the TV shuts down..There are safety circuits in the power supply that shut down if any of 4 voltages are either to low or high and I think that is what is happening. To fix it your going to either need a new main board or you can replace the audio output IC...chances are if you look at it you will see it has bulging. Good luck!
2/5/2018 3:34:32 AM • Vizio 60"... • Answered on Feb 05, 2018
Connect Dell Inspiron 6400 to VIZIO E601i-A3 60-inch 1080p LED HDTV using VGA Connector
When you connect the vizio try changing the resolution settings on your laptop to see if that makes a difference. Could be that your video card output is not really compatible with the higher requirements of the Vizio.
9/20/2017 2:50:43 AM • Vizio 60"... • Answered on Sep 20, 2017
I have a vizio E601i-A3 tv that has just lost its picture. The tv powers on and has back light and sound just no picture. From what I understand this could be that the t-con board may have gone bad?
Can be the TCON board or the Main board. Can confirm by replacing the TCON board. If you wish to get some details; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
1/3/2017 3:07:33 AM • Vizio 60"... • Answered on Jan 03, 2017
How can I remove rear panel?
If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
12/28/2016 8:54:02 PM • Vizio 60"... • Answered on Dec 28, 2016
2answers
How do I remove back cover from Vizio E601i-a3 60" tv once all screws are removed? Still seems tight around the edges? Thanks
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Disassemble procedure to many popular devices are given with illustrations.
12/28/2016 3:54:12 PM • Vizio 60"... • Answered on Dec 28, 2016
I have a Vizio E601i-A3. The "Vizio" emblem does not light up and the screen does not light up. Is it most likely power board that needs to be replaced?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
11/27/2016 11:40:55 AM • Vizio 60"... • Answered on Nov 27, 2016
I need assistance with a repair for my Vizio LCD TV
You just contact any service technician. http://electronicshelponline.blogspot.com/
9/19/2016 6:17:51 AM • Vizio 60"... • Answered on Sep 19, 2016
Vizio E601i-A3 Does not power on
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary. Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
8/1/2016 1:06:29 PM • Vizio 60"... • Answered on Aug 01, 2016
The vizio set will not respond to remote to turn set on.
Point the remote at your cellphone camera and press a button. You should see a flicker from the remote if it is working. If no flicker then remote is defective. If you have a flicker then the problem lies in the t.v. could be the receiver or another issue in the t.v.
7/21/2016 12:47:43 PM • Vizio 60"... • Answered on Jul 21, 2016
TV turns on, lights up, but no menu, logo or any other picture. There is sound though. Wondering what board to replace. thanks
7/4/2016 7:19:15 AM • Vizio 60"... • Answered on Jul 04, 2016
How to fix no picture on vizio e601i-a3
Try the flashlight test for image in a darkened room. If you see image checkout the inverter board.
6/23/2016 2:16:53 AM • Vizio 60"... • Answered on Jun 23, 2016
Would replacing the main board fix my TV?
We can't predict what might have been happened during a lightning strike. If the TV is dead now; the main power supply regulator board [SMPS] board is fault. If so, you have to replace it first. then only we can get information about the condition of the main board. If the TV was connected to external Ariel or cable; before the lightning stroke; the possibility to damage to the main board too is there upto 80%. In fact, if both of this boards are damaged, it might cost around 2/3rd of the total cost of a new TV. The decision left to you. Do whatever you want. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
6/22/2016 5:35:52 PM • Vizio 60"... • Answered on Jun 22, 2016
VIZIO TV WONT TURN ON
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electro-medical.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary. Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
5/2/2016 7:23:20 PM • Vizio 60"... • Answered on May 02, 2016
I have a vizio e601i-a3 that is frozen on the logo screen. I've tried various strategies to get it to unfreeze. Nothing works. I saw a video that mention replacing the T-con board might solve it.
Do a reset to this set, and check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
4/19/2016 8:02:27 AM • Vizio 60"... • Answered on Apr 19, 2016
How to diagnose television fault?
diagnose television fault Check the attached links,instruction and guides, Good luck "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info." http://www.avsforum.com/forum/167-plasma-flat-panel-displays/1491814-common-diy-diagnosis-repair-info-plasma-led-lcd-ccfl-lcd-tv-sets-monitors-display-devices-mostly-power-supply-repairs.html How to Diagnose TV Problems http://www.repairfaq.org/samnew/tvfaq.htm Latest Repair Tips
4/16/2016 4:23:27 AM • Vizio 60"... • Answered on Apr 16, 2016
Vizio E601i-A3, blue vertical line on screen in center.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electro-medical.blogspot.com/ http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD screen are similar, irrespective of its brand and screen size.
3/8/2016 6:49:36 AM • Vizio 60"... • Answered on Mar 08, 2016
Vizio 60" E601I-A3 Full HD LED-LCD TV Logo
90 questions posted
Top Vizio Televison & Video Experts
Ekse
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Vizio Televison & Video
Most Popular Question
remove back cover from vizio e601i a3
  • Televison & Video
