SOURCE: Logitech Cordless MX 700 Mouse
My mouse pointer was drifting for no reason, until I looked closely at the laser and saw a hair across the optical port. Removed with tweezers. Drifting stopped.
Thanks.
SOURCE: MX 3200 Cordless Laser Keyboard - Logitech
Press the FN key and *at the same time* press the F10 key for 1 second.
The first part of the time should start to flash.
Use the up / down keys to change the hour, then press TAB. The minute figs. should now flash. Use up/down to change the minutes and press TAB.. do the same with the date and month etc, you can also set 12h or 24h clock.
When you are finished press ENTER.
SOURCE: Erratic Logitech cordless optical mouse
ive had the mx700 for two years and im very comfortable with it.
I think you problem lies not with the mouse or the driver, but rather the mousepad.
Since the mx700 is not a lasermouse, but "only" optical, it still needs a decent pad to work flawlessly.
Ive had problems with these kind of mice using blank paper, magazines or tablesurfaces.
Try to get a real mousepad from somewhere (should be really cheap), that should do the trick =)
I upgradet to a razer diamondback later which is a laser mouse (1600dpi, while optical mice (with the red light) have 800dpi). Some ppl say that this is too much, and not needed (you can get even higher specs =) but i felt a world of difference, it just works everywhere! (except for mirrors and glas =)
SOURCE: problem with LOGITECH S 510 cordless keyboard and mouse..
I have this same keyboard/mouse set and love/hate it when the batteries die. After you change the batteies, power on your pc, press & hold the connect button on the bottem of the keyboard first and then the connect button on the transmitter. Release them and wait for a few seconds. Repeat the same steps for the mouse.
When I have connection issue with this keyboard after new batteries, I have found most of the time the problem is the connection to the pc and/or batteries in wrong. Good Luck
C2Solutions
