2001 Pontiac Montana Logo
Posted on Feb 03, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Does not seem that there is any electrical current. Checked all the fuses, they are fine. It doesn't seem like a battery problem as there is absolutely no current. Drove it last night everything worked. This morning nothing
david lasky
Level 2:
New Friend:
  • Expert 173 Answers
  • Posted on Feb 03, 2011
david lasky
Expert
Level 2:
New Friend:
Answers
173
Questions
Helped
50284
Points
430
Is the battery dead? Your alternator may be bad. If you drove it last night you may have driven on battery power and not realized it. You should have gotten some kind of warning message. Need to know if the battery is dead.
1helpful
3answers
Radio suddenly doesn't work and instrument panel doesn't work
Ok, i had the same problem a few months back, in my case my car was only a year and a half old and had just washed the engine at the local carwash. Fuses were ok and battery was in new condition, we found out that water had reached the Alternator and this messed up the whole electric system, Some people say you can blow dry your alternator (If this is the case) or take it to an electrical technician
Reverse polarity check list
start with ignition switch to starter components for power --look for short burnt connections and or components [ relays-solenoids etc ] if good may need to have computer checked
Right brake light doesn't work with lights on. Switched R bulb and socket to left, and it works. Radio also goes off when headlights r applied. But radio comes on when I turn dimmer switch all the
check for power and ground. One should be at battery voltage and the other ground. Somet5imes ground can't handle the current from the bulb so try to make a connection to ground. I try to either use the fuel tank or run a wire from the battery.
Second reason the turn signal switch can go bad and keep the battery voltage from reaching the bulb. I will also assume you checked the bulb on the other side that you know works fine. I use electrical contact cleaner inside turn signal switch. Move the lever
rapidly to clear any possible dirt.
Mage Talesin
Car tries to start but cant seem to turn over. battery seems fine
Get your battery tested, if your battery has failed internally sometimes jump starting doesn't help as the battery is pulling all the current away from your starter.
The engine turns over fast enough to start but will not start when i turn the key i dont hear the fuel pump at all i checked all the fuses they all seem to be fine is it possible my fuel pump has gone bad
It's possible. You will have to test the pump(at the fuel tank electrical connection) to see if it's getting current when the ignition is turned on. If it's getting current, the pump is most likely bad.
2answers
2answers
Total black Out...
Replace the battery with a new one . Depending on the age and condition of your current battery if it was ran all the way dead it will no longer hold a charge
Top Pontiac Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Pontiac Expert? Answer questions, earn points and help others
