Refrigerators Logo
Posted on Feb 03, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Frigidaire frs22zrfw2. Slow water flow from door. Not enought water going into icemaker to make ice. Water seems to be flowing ok into the filter.
Anonymous
Level 3:
  • Master 403 Answers
  • Posted on Feb 03, 2011
Anonymous
Master
Level 3:
Answers
403
Questions
0
Helped
107166
Points
1133
Your filter probably needs to be changed, was the water dispensing faster before?
Not enought water to ice maker
Can you provide a make & model # for the unit?
tip
I have the Kenmore version of this product and the same thing happened. My...
I had water leaking in to the freezer compartment of my LG french-door refrigerator (LFD25860). It was getting on to food in the main basket and embedding it in a block of ice, as well as puddling-up on the bottom of the freezer and eventually blocking the door from closing properly. Because the water seemed to be covering a wider area than you would expect from a blocked defroster drain I didn't believe that my problem was covered by the other FixYa recomendations -and it turned out I was right.
The problem turned out to be that the "funnel" that the water flows through to fill up the ice tray was blocked by a solid piece of ice. When the icemaker would call for more water it would flow down the clear tube (with the open slots on the top) hit the ice and spray/overflow in to the freezer compartment.
The solution was obviously to pop this ice out, but that did require me to remove the icemaker from the wall of the freezer compartment. To do this you
  • remove one screw from the bracket on the bottom of the icemaker
  • Slide the icemaker up and slip it off of the two screws with rubber grommets on them.
By the time I got to that stage I had already removed the basket from the main drawer and removed the pull out tray/basket from the drawer pulls (by simply lifting the plastic tab on the right side and lowering the plastic tab on teh left side). I am not sure if you can remove the icemaker without this step, but I believe so.
Also, if you want to entirely remove the icemaker from the freezer there is only one plug with wiring to undo. As I mentioned above, the water hose doesn't not connect to the icemaker, it ends above the "funnel" and the water drops in. So removal is much simpler than you might expect.
As for the cause of the ice block, I am not sure but I believe it was either because the ice maker made too much ise one time and some cubes could not pop out. When additional water entered the funnel it didn't flow in to the ice tray, backed up, and froze in the funnel. The other thought is that when the door was not closed properly while our grandparents were visiting, the ice melted and subsequently re-froze causing the problem.
on Oct 05, 2009 • LG LFD25860
JCD-23 making too little ice
Check the water flow to the ice maker. Turn the supply water off, loosen a fitting near the ice maker and then turn the water on. You should get plenty of water. If it is slow, check the filter.
1helpful
3answers
Water will not stop flowing in to icemaker
Dirt in body of icemaker water supply valve. OR. Ice maker timer stuck when it selected "add water to icemaker.
The first solution is simple, change icemaker water filter and disassimble valve to clean.
The second is simple, buy a new icemaker.
Water overflows from icemaker & freezes in the freezer. Makes three ice cubes in a day & the water is extremely slow to fill glass from freezer door!
If both the water in door and ice maker are experienceing slow water problems the common point is the water supply itself.
This can be caused by:
1. Water supply shut off valve is partially closed or blocked with debris.
a. TURN water supply OFF
b. Remove the water line from the rear of the refrigerator ABOVE the in line filter (if one is installed)
c. Place the removed line into a bucket.
d. Turn on water supply and check flow. It should fill an 8 Oz glass in about 8 seconds.
If it passes this test then the water supply is fine. If it FAILS this test either cflear the obstruction in the line or replace the water supply valve from the house connection.
Test 2 (Water supply is OK
Reconnect water supply to external in-line filter (If installed) or water valve assy connection.
Your unit has a Verticle filter that if it is clogged will cause slow water flow.
Test water thru the door for the same amount of water flow. It should fill an 8 Oz glass in 10 seconds or less.
If it does ot do this then the VERTICAL internal water filter is clogged. (5 months or 500 Gallon change interval)
REPLACEMENT filter is PN LT500P but there are several like / suitable aftermarket replacements for the LT500P number.
As for the ice maker freezing up. There is only one cause for this and that is the water valve assy itself is bypassing water when it is supposed to be closed. The only remedy for this is to replace the water valve. They are not repairable.
The valve is available through sears parts direct:
http://www.searspartsdirect.com/partsdirect/part-number/LG-Parts/Refrigerator-Parts/5221JA2006D/0046/795/Model-LSC26905TT/3204/0165000?keySuffixId=NA&productTypeId=x&searchModelNumber=LSC26905TT&subCompDesc=Ice/water%20parts&brandDesc=LG&modelDesc=REFRIGERATOR&blt=11
Thanks for choosing FixYa.
Kelly
3helpful
2answers
Water is not going into icemaker, I've replaced
I have a maytag side by side with water in the door, the cold water works but the icemaker doesn't. No water flow into the icemaker, it doesn't appear to be iced up. Can not tell if the selenoid works.
HAVE WATER FLOW FOR DRINKING/BUT NO ICE MAKING GOING ON
is not the filter because you are getting water from the 1 icemaker or the water valve
Ice Maker
Likely that the water supply tube to the icemaker is frozen. It will be a white rubber tube on the right side of the icemaker. Warm it with a hair dryer, remove it from its aluminum tubing, and make sure there is no ice all the way back to where the supply tube comes from the water valve. After thawing, your icemaker should start working again.
Now..... why did it freeze? Most likely, there is a restricted airflow to the back of the unit, which is need to keep that aluminum supply tube just warm enough to assure all the water flow OUT of it into the icemaker, and doesn't freeze up on contact. Make sure your coils and the airspace under the fridge are completely clean (vacuuum them well) and it should cure the problem.
2answers
Slow water flow
dadcanfix. There are two possibilities here. One could be the water valve itself, clogged or not seating or opening properly. The second would be the water tank on the refrigerator side, partially frozen. I believe they have a kit now with coiled tubing that replaces that tank because of the trouble they had with it. Remove the refer drawers and take a hair dryer and go over the tank lightly. See if that improves the water flow. Catriver..post back.
2answers
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
