SOURCE: when i put my action replay in my dsi it says there is no game.
it must be because the game cartridge is dirty. It happened with me too. First, try to blow out the dust in the action replay and the yellow data part of the game cartridge. Then if that doesn't work when you plug it in, try to wet it. Use rubbing alchohol with a tissue or an alcohol swab and rub the yellow data part of the game cartridge. It's ok, it won't get destroyed. Since data streams can be cleaned without the use of water and using alchohol cleans it. I used it on my Super Monkey Ball Touch & Roll and it was dirty because I didn't use it for a long time. Then, I wiped with an alchohol swab. After that, I put it in my Action Replay and it went to the codes already.
SOURCE: my dsi says "An error
there is a factory reset code you must press all these buttons at the same time
left,right,select,start
this will reset your dsi to the day you first perchased it..........
SOURCE: My DSI does not read the action replay DSI
maybe action replay codes dont work for dsi but it works for ds and ds lite
