Plesae make sure you have 2 different working condition LAN calbe with youto perform the steps mentioned below:
1. Make sure the Main Intenet calbe is connected to Router.
2. Make sure alternative LAN calbe is plugged in to LAN 1,2,3 or 4 at the back of the router and other end is plugged into your laptop.
3. Make sure you WLAN, DSL, Power, any one LAN cable pluggedin lights are blinking.
4. On your laptop keyboard, press start button and also "R" at the same time. This will give you run command box.
5. Type "cmd" and hit enter. This will open black background command prompt window.
6. Where the cursor is blinking, there type "ipconfig". This give you the IPaddress of the machine.
7. Copy or wirte down the IP address and open Internet Explorer.
8. In IE top address box of http, type the default gateway adress... Eg: 192.168.1.1
9. This will prompt for User ID and password.
10. Enter User ID as "admin" and password as " admin" or "password"
11. That will take you to router configuration page. Sellect Wireless and then wireless security.
12. Choose security type as open and Encryption type as WEP
13. Network security key as your choice of 10 digit numbers shich only you or your family members can use and access internet. and clikc submit. Later you can unplug the LAN cable from laptop as it will on wireless.
This should help you to go on wireless and help you to solve your problem.
Please watch the youtube links mentioned below:
Thank you
Gowtam R
