I have done this a couple of times over the years. Often, it is caused by an accumulation of crumbs around the thermal shut off sensor. This causes the toaster to shut off quicker because it gets too hot.
The fix it is unplugging the toaster, taking the outer shell off and cleaning all visible residue out of the toaster. Compressed air, wooden skewers, and slightly damp, lint free cloths are helpful.
Reminder: if wiping with damp cloths, please let toaster thoroughly dry before reassembly.
This was from another site but is the same as I would say or instead of the sensor, when you push down the handle, you are making a magnet circuit by putting the last part of transformer frame into place - a jammed piece of old toast can prevent this and then your toaster won't work. Unplug it, take it to the garbage can or the sink and pull our the crumb trays and after that, within reason give her a good shake and see what you dislodge
Eric
Good Thi
I was trying to help you out here. Maybe this will help some? I was going backto some customers that asked questions in the recent past and even fartherback. It appeared that no one answeredsome of them, So, I thought I would take some of my personal time to see if Ican help. Even though this Informational site may not have your exact model orbrand, this site will help you a lot. Here is a site link about everything you want to know about toasters andpossibly yours, from repairto trouble shooting it. http://home.howstuffworks.com/how-to-repair-small-appliances1.htm Please if this helped you at all, if you can find the time and in your heart torate my help and some kind words written would be appreciated for my free help, I would appreciate it.
Here is also my direct link to my own pages of other areas of my expertise forother problems you might have in Automotive, Appliance, and Electronics. DropIn anytime for my help.
Anything can be fixed but yourctoaster has an intemittent fault...probably due to the build up of crumbs in thecwaste tray in the bottom of of the toaster
This is a maechanical fault and all you need to do is look for a lock that clicks to hold the tray down .This latch is controlled by the bimetal which when hot moves off and releases the tray.
So this strip could have moved off or damaged with use.
Might have to replace or try to repair to keep it in the lock postion..
I found another site that described the fix. On the bottom of the toaster, after removing the crumb tray, there is a screw in the middle that can be turned to adjust the sensitivity of the lift mechanism. Here's a link to the site http://www.automaticbeyondbelief.org/fixing.htm
