SOURCE: Dishwasher Hoover HD98E
E3 means water is "not heating" for this model. Check the heating element, thermostat/thermistor or printed circuit board with power OFF.
SOURCE: Our Hoover HD98E Dishwasher stopped working
its possible that your timer has a bad contack at this spot the machine stops but the drain valves open try advancing the timer one notch to see if it will work if yes relace the timer thanks from gilles
SOURCE: new hoover HED 6612-80 dishwasher
hi, i have same problem with my hoover dishwasher same model as your own, did you ever find out how to fix the problem. your help would be really welcomed. thanks lesley
SOURCE: Leak from salt reservoir on the DT999
Replace water softner seals (Hoover spares reference: 91941698) as stated previously. Harraps were doing them for £6 each. The softner is accessed by removing the R/H panel and unscrewing the air break ring nut from inside the machine. They are not a standard size so oem o rings are recommended.
SOURCE: dishwasher overflows from front
Hi andrew did you get this fixed as it sounds identical to my problem.
Ian
