Mitsubishi WD-52525 52" Rear Projection HDTV Logo
Posted on Jan 21, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Every time we turn on the TV, we get the message Did you replace the lamp press ok, if you didn't replace the lamp press cancel. Should I ignore this until the lamp burns out or replace it?
Anonymous
Level 2:
  • Expert 98 Answers
  • Posted on Jan 21, 2011
Anonymous
Expert
Level 2:
Answers
98
Questions
0
Helped
16431
Points
161
Make sure the AC power source is uninterrupted, plug into a wall to see if this fixes problem. Lamps should be replaced as soon as there is a problem - dim picture or intermittent operation of tv. Mitsubishi lamps last an average of 1-3 years. If you run a lamp longer than 3 years, older lamps start running hotter. When they run hotter, they will damage the optical engine, causing discoloration or the cooling fan to go out. The problem your tv has is that the power/digital module is in the process of going out. There are numerous capacitors that blow, and sometimes the digital board fails. You need to have an authorized shop pull the digital/power module and send to Mitsubishi for rebuild. We charge $225 labor and $300 for the part in our shop for this. It is a good (but expensive) fix!
1helpful
I got the 'lamp needs replacing' message. Ignored it. Now my tv screen is black when you try to turn it on and the blue button on the power button flashes?
You haven't replaced the lamp at time. Replace a new lamp along with its ballast and make a lamp time reset. If you wish to get more details about the lamp replacing procedure to Panasonic PTVs, check this link.
Memory full
Press 'Job Cancel / Status Monitor', a message shows "job cancel' then press 'OK' after that ppress the left or right arrow key to show a message 'TX / RX', then press 'OK'. Again press the left arrow key once to select 'Yes', finally press the 'Stop' button to return to the main menu.
If this didn't work try installing the latest driver from here
Hope this helps, thanks for using fixya.com
2helpful
Replace tv lamp but the replacement light is still on how do I turn it off
Hello
Reset the lamp hours through the TV setup menu each time you replace the lamp cartridge. Otherwise,
the lamp warning message will reappear sooner than necessary.
After you change the lamp cartridge, you must reset the lamp
reminder through the TV Setup menu
Go to the setup menu, there you can see the reset proceedings with illustration. OK.
I cant receive mms
The phone has a 4-way directional 'Navi' key and 2 soft keys on either side of this and 4 additional soft keys either side of the keypad. The Navi key can also be pressed in to select options.
1. Select 'Menu' (press Navi Key).
2. Scroll to 'Settings' and select (press Navi key).
3. Scroll to 'Configuration' select (press Navi key).
4. Scroll to 'Personal configuration settings' and select (press Navi key).
5. Press 'Options' (left softkey) highlight 'Add new' select (press Navi key).
6. Highlight 'Multimedia msg.' and select (press Navi key).
7. Highlight 'Account Name' select (press Navi key), enter 'giffgaff MMS' then 'OK' (press Navi Key).
8. Highlight 'Server address' select (press Navi key), enter http://mmsc.mediamessaging.co.uk:8002' and 'OK' (press Navi Key).
9. Highlight 'Use preferred access point' and select (press Navi key), highlight 'No' and 'Select' (press Navi key).
10. Highlight 'Access point settings' and select (press Navi key).
11. Highlight 'Proxy' select (press Navi key), Highlight 'Enable' and select (press Navi key).
12. Highlight 'Proxy address' select (press Navi key), enter '193.113.200.195' and 'OK' (press Navi key).
13. Highlight 'Proxy port' select (press Navi key), enter '8080' and 'OK' (press Navi key).
14. Ignore 'Data bearer' as this is set at 'Packet data'.
15. Highlight 'Bearer settings' and select (press Navi key).
16. Highlight 'Packet data access point' select (press Navi key), enter 'giffgaff.com' and 'OK' (press Navi key).
17. Ignore 'Network type' as set at 'IPv4'.
18. Ignore 'Authentication type' as set at 'Normal'.
19. Highlight 'User name' select (press Navi key), enter 'giffgaff' and 'OK' (press Navi key).
20. Highlight 'Password' and select (press Navi key), enter 'password' then 'OK', verify password and again select 'OK' (press Navi Key).
21. Press 'Back' (right softkey) 6 times to get to the main menu.
22. Highlight 'Messaging' and select (press Navi key).
23. Scroll to 'Message settings' and select (press Navi key).
24. Highlight 'Multimedia msgs.' and select (press Navi key).
25. Ignore 'Delivery reports' as preset to 'No'.
26. Ignore 'Image size' as preset to '640x480'.
27. Ignore 'Default slide timing' as preset to '00:08'.
28. Ignore 'Allow multimedia reception' as preset to 'Yes'.
29. Ignore 'Incoming multimedia messages' as preset to 'Retrieve'.
30. Ignore 'Allow adverts' as preset to 'Yes'.
31. Highlight 'Configuration settings' and select (press Navi key).
32. Ignore 'Configuration' as this will change to 'Personal config.' with the next step.
33. Highlight 'Account' and select (press Navi key).
34. Highlight 'giffgaff MMS' and select (press Navi key).
35. Press the right softkey 5 times to get back to the standby screen.
The MMS settings are now complete.
2helpful
I have a large screen panasonic tv. The lamp
Turn On tv.
Press and hold Volume Down button on TV Front and PIP/ SPLIT button on Remote at same time for 6 Seconds to reset Lamp Timer and tv will show you timer reset message screen.
Hope this info will help you.
Thanks.
3helpful
2answers
Resetting lamp hour meter on panasonic tv
press volume down on tv and pip or split on remote
Replace lamp on dlp tv
On the side of the TV press the menu and volume up buttons at the same time for three seconds. The 'reset lamp timer?' will appear on the screen. Press the OK button to accept. You're done!
44helpful
4answers
Ink system has failed 0xc18a0206
This is easily fixed with the following key sequences. You do NOT have to open the printer and unplug a circuit board.
1) press * and # at the same time
2) press 1, 2, 3 and “support R0632M” should display
3) press > and “information menu” should display
4) press > and “configuration menu” should display
5) press OK and “hardware failure status” should display
6) press OK “failure status: clear”. Press OK to clear
7) press CANCEL
8) press CANCEL
9) press CANCEL
10) turn printer off, unplug power cord for 2 minutes, plug cord back in then turn printer back on.
NOTE: I did this and the fist time the error came back. Do the sequence again (as I did) and the error will be replaced with the usual print cartridge initialization screens. Print a test page to make sure.
12helpful
3answers
Lg rear projection model: RT52SZ60db
You need to use the original LG RT52SZ60DB remote.
  1. Press MENU buttons on the REMOTE and on the TV at exactly the same time and hold for about 3 seconds (TV buttons are just below lower left of screen)
  2. Scroll down the SERVICE MENU to No. 14 LAMP REPLACE
  3. Press VOL |> button to enter lamp hours
  4. Press OK button to RESET hours, or CANCEL/EXIT to Exit menu
Hope this helps.
Cheerz ;^)
Reset for new lamp
take the lap back out and put back in
After replacing the lamp cartridge, when you power on the TV, the message "Did you change the lamp? Press ENTER for Yes, press CANCEL for No"will appear, press ENTER to reset.
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
