Question about Mitsubishi WD-52526 LCD TV
Replace tv lamp but the replacement light is still on how do I turn it off
Posted by scotts1571 on
    Top Expert:
  • Mitsubishi Master
  • 76,416 Answers
Hello
Reset the lamp hours through the TV setup menu each time you replace the lamp cartridge. Otherwise,
the lamp warning message will reappear sooner than necessary.
After you change the lamp cartridge, you must reset the lamp
reminder through the TV Setup menu
Go to the setup menu, there you can see the reset proceedings with illustration. OK.
Posted on May 12, 2011
Testimonial: "This very helpful and fast!"
4 Related Answers
Anonymous
SOURCE: lg tv 52sz8r-tb new lamp installed, red lamp light still on
you need to reset your lamp hours timer. as far as i know this can only be done with the service remote
Posted on Jan 12, 2010
Lashawn Robinson
  • 1153 Answers
SOURCE: Replaced lamp and now can't get a picture
Hi Sally Jo, Unit powers on and works properly for a while then shuts off with a red lamp LED (lamp error). Suspect bad lamp part # 915P020010 2. Lamp enable line at J14 pin 6 does not switch to 5 volts after turn on, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 3. At power on the lamp turns on and off three times and then the unit shuts down with a red lamp LED (lamp error). Replace the Light Engine part # 939P977010 4. Check for 12-volts DC at J-9 connector pin 4 on the Engine Driver PCB, if missing check for an open F9A09 on the Power PCB, if it is open replace F9A09 part # 283P127060 and the Light Engine part # 939P977010 5. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on but does not go back to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 6. Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if missing replace the Power PCB part # 934C148001. Hope this helps!
Posted on Sep 18, 2007
Anonymous
  • 8 Answers
SOURCE: Sony KF-50XBR-800Replacement Lamp blew after 1 minute
Although this is rare, the problem is the lamp driver board, commonly called the ballast board. Follow the leads back from the lamp an you will find a smallish rectangular board with one large connector and one small one (besides the two wires going to the lamp). If you feel confident, they can be ordered from a Sony parts distributor such as Vance Baldwin or Union Electronics Distributor for about $115 - $150
www.ued.net
Just search under the parts for "Sony" "ballast" and the model number of your TV. Or just call them at their 1-800 number.
If you dont feel confident, you can have a shop repair it for about $450
Posted on Mar 20, 2009
Anonymous
  • 17 Answers
SOURCE: Samsung 50" DLP - Lamp Light Blinking after bulb replacement
Listen closely. The tv should make a high pitch whine as it turns on. If it does wait and see if it tries this a few times. If yes then check the bulb, I have seen cases where the lamp shoves the power connector back into the set. If the tv starts with a grown or heavy vibration noise, then your color wheel may have broken and needs replaced.
Posted on Jul 11, 2009
Power light blinking red..tv won't come on after replacing lamp
DLP TV Repair Tutorial - DLP Bulb Won't Turn On - YouTube
? 14:13
https://www.youtube.com/watch?v=5frOnh58Z6M
Jun 26, 2013 - Uploaded by ShopJimmy.com
DLP TV Won't Turn On Common How to Replace Ballast DeadTV ... solid green power light plus sound ...
• New Lamp Doesn't Turn On? Try This! - Fix Your DLP - FixYourDLP.com
www.fixyourdlp.com/forum/viewtopic.php?t=19
Mar 12, 2009 - 50 posts - ‎36 authors
Mine did the same thing after replacing the lamp. ..... TV won't turn on and Color Wheel is GOOD, Temp sensor is GOOD, Ballast is GOOD, and ... • NEW Bulb- still not working
Jan 14, 2010
• Resetting the Samsung DLP Lamp Counter/Hour Meter
Mar 20, 2009
• Samsung Dead Lamp, Black Screen, or Intermittent
Mar 12, 2009
More results from www.fixyourdlp.com
Samsung DLP: replaced lamp however tv won't turn on - HDTV ...
Dec 09, 2015 | Televison & Video
What's your problem?The tv comes on for 1 second and turns off and the red lamp light is on
Replace the lamp. The red lamp light is indicating an issue with the lamp. You can get the replacement lamp with installation instructions from www.tvrepairworld.com
Oct 19, 2012 | Mitsubishi Televison & Video
Replaced lamp but lamp light still blinks orange
I have a wd-57731 The lamp light blinked orange. i replaced the lamp turned the tv on and the timer blinks green for one minute and then the lamp light blinks orange again. It won't turn on. Can you suggest anything?
Nov 22, 2011 | Mitsubishi WD-57731 57" Projection HDTV
Bought Samsung dlp h-l 5667w new in 2005. Replaced lamp, fan, and color wheel in 2008. Now lamp lights up and lamp indicator on front lights up, fans turn on, but tv picture will not show. After a few...
It time to replaced the tv projection lamp again,the tv projection lamp life span have ended.The tv projection lamp life span only last 2000 hrs.Average out like 1 1/2 or 2 years max for tv on watches 4 or 5 hrs of tv every days.
Jul 07, 2011 | Samsung HLR5667W 56" Rear Projection HDTV
Powers off with a blinking standby light for 45 blinks
Yes, its clear symptoms of weak lamp that is going to end of its working life, soon tv will show you lamp light.
Replace lamp to solve the issue, lamp replacement procedure is easy and written in user manual.
Please buy Sony original lamp for good picture in tv.
Thanks.
May 25, 2010 | Sony KDFE50A10 50" HDTV
Tv tries to turn on but then turns off with a red
Lamp light on again?must replaced the lamp again,the lamp hours it up.
Mar 30, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Tv turns off (both video and sound) after running for 20 sec and then turns on after 20 sec. This pattern continues over and over. None of the lights are blinking. Lamp is less than 2 yrs old and is...
TV will show Lamp Light warning if lamp got broken or dead.
Symptoms of TV shows lamp is weak and will be replaced. Weak lamp consume more current than allowed ratings and causing activation of protection circuit that shuts off TV and TV turns on again itself, that is why no blinking red light.
Please replace lamp in your Sony KDF-E55A20 TV, lamp replacement procedure is easy and written in user manual, click Sony Support to download user manual copy, if required.
Always buy Sony original lamp for TV safety, Sony original lamp is available in Sony Accessories Store for $200 with following part number..
A1085447A... LAMP BLOCK ASSY XL-2200U
Hope this info will help you.
Thanks.
Dec 31, 2009 | Sony Televison & Video
Samsung DLP TV time, temp and lamp lights blinking... won't turn
Les,
I'm not a TV repair guy but my owners manual states that when all three LED's or lights on the front of the TV are flashing, that the lamp needs to be replaced. Might want to look into this. Good luck!
Greg
Aug 30, 2009 | Samsung DLP HL-P5663W 56" TV
Tv not turning on
I also have this model. A few months ago, when I turned on the tv, it told me my lamp was in need of replacement. just yesterday, my tv did the same as you....the blue light flashed and then the lamp light kept flickering. All I can say is your lamp needs to be replaced.
Mar 19, 2009 | JVC HD-56G657 Television
WD-62327 Lamp
OSRAM VS. PHILLIPS
This is about buying replacement bulbs for the WD62327 TVs.I dont know about the other models but I purchased a PHILLIPS replacement bulb and it worked for about a week and then those dumb flashing lights and no TV. I did some research and others were saying that you had to replace some condensers. Shop would do it for 600 dollars..Well i sent the bulb back and bought an OSRAM replaement bulb. The TV is now working perfect.
Sep 17, 2007 | Mitsubishi WD-62327 62" Rear Projection...
Mitsubishi WD-52526 LCD TV Logo
714 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
