Propellerhead Reason 5 Logo
A
Anonymous Posted on Jan 16, 2011
The sound on my synths is not working. I just bought reason5, and all that makes noise is the kong drum machine. I am very new at this so it is probably a stupid problem, but whenever I pull up the keyboard and play notes, the synth says that notes are getting played but there is no sound. Please help!
Anonymous
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Apr 13, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
570
Points
Okaye, i justt figured itt outt, hopefully you gett an email aboutt this postt...
so anywayz yo,
how many instruments you have hooked up to your mixer? thats the key, #1.
make sure you have atleast ATLEAST 2 mixers in your start up program, once you use the max output input for your original mixer, the next instrument patch you load will not be routed, (no more space), you'll have to route it manually (press Tab) *get familar with routing your own devices, for reverb/chorus and such,
this applies to everything about recieving sound from your project/keyboard. and just route your extra devices on the new mixer --they go up to 14 channels, i have like 22!
so thats my solution, hope itt applies.
Dre'
South Caro-line-em- up
~1~
Yamaha dx7 new battery. Presets re-loaded - a couple work, the rest not. Any ideas?
There could be a few possible causes for this issue with your Yamaha DX7 synthesizer. Here are a few things you can try:
  1. Check the connections: Make sure all connections between the battery, the synth, and any external devices are secure and in good working condition.
  2. Re-initialize the synth: You can try re-initializing the synth by pressing and holding the "Data Entry/Memory" button while turning on the power. This will reset the synth to its default settings and may fix any issues with the presets.
  3. Check the synth's memory: If the synth's memory is full or damaged, this could cause problems with the presets. You can try clearing the memory by pressing and holding the "Data Entry/Memory" button while turning on the power, then selecting the "Erase Memory" option when prompted.
  4. Check the synth's firmware: It's possible that the synth's firmware could be causing issues with the presets. You can try updating the firmware to see if that resolves the problem.
1helpful
How do I connect my GK3 equipped guitar to an Electric Piano or Synth ?
You cannot connect a Gk3 directly to an electric piano or synth. What you have to do is connect the 13 pin DIN connecting cable from the gk3 to the input on a Roland guitar synth unit like GR 20 or the GR 55 which supplies the desired instrument tones as required. The synth can be connected via 5 pin midi cable to an external synth to provide further tones...I personally have never used a keyboard to provide extra tones because I am a guitarist so only used synth modules and not keyboard ....remember also you need an amp or pa system to hear the sound output from the guitar synth module or external module.
2answers
How do i connect my keyboard and my laptop?
Download USB MIDI driver for yamaha from yamaha website,and install to laptop.
Next:
Make sure the POWER switch on the instrument is set to OFF,then use an AB type USB cable to connect the instrument to the laptop.
After making the connections, turn on the power of the instrument.
Laptop will immediately notify that new hardwares is connecting and automatically install the drivers. Wait until the process is finish.
Thats all. In Ableton,the setting MIDI input must be set to USB MIDI.
Can a Korg CX3 Organ 61 keys be compatible with the RolandFantom XR module?
Hi, from what I can tell you cound plug your CX3 into the synth module with a 1/4 inch patch cable and run the audio through it, however I think you will be quite limited in what you can do to modify your sound.
Where the synth really works well is when you feed it digital input data. For you to be able to do that your CX3 would need midi outputs and while I don't have one, I looked it up and can see that the CX3 is too old and does not have midi capability.
Midi (musical instrument digital interface) is a common language that allows musical devices such as your fantom to communicate with other devices. A keyboard with midi running into a synth is in essence just a control surface, a way for you to input data into your synth module, it is making no sound itself, but rather outputting digital data into your synth which in turn generates the sounds you want it to. There are allot of keyboards out there that are only for this purpose and are simply controllers. For example, M-Audio Oxygen 61 - 61-Key USB MIDI Controller. I'm afraid your CX3 is just too old to be able to do this, however, I imagine some of the sounds that thing makes are very vintage and good, and modern synthesizers often times just cant reproduce that (though they are getting batter all the time). Hope that helps :)
Dec 20, 2013 • Music
It just won't turn on! i've plugged it into the mains, and connected it up with my guitar and amp but the red light won't come on and won't make any noise.. i only just bought it, so have never used it so...
Make sure the adapter is the correct one. Sometimes bad ada[ters or backwards polarity ones are supplied. Try using this on a 9 volt battery. If it works, check the adapter.
I have the yamaha dtexpress and a midifase conect but cant get anny sound to the computer??????????????
try a midi loopback device or a viruual midi cable such as sonys virtual midi cable: http://www.johnrofrano.com/tutorials/virtualmidirouter.htm
i dont know if this one will work, you could also search for loopb1 and hubi's midi loopback device, one of these should work.
what you have to do is use one of these programs, or something similar, to connect your midi input to the soundcard's midi wavetable or to your midi/synth/sequencing software's midi input.
also, the drum machine should be set to output to midi channel 10. make sure that your software is set to recieve on midi channel 10, if applicable.
Just bought the EWI4000s plugged it in but no sound.
First of all I recommend reading your entire manual cover to cover. Then read it again with the EWI in hand. Go step by step following the setup procedure. You have a complex instrument so it is very easy to miss something or make a mistake. Here is a link to the best wind synth website in North America:http://www.patchmanmusic.com/ There is an 1/8" jack on the instrument for headphones. There is also a 1/4"unbalanced jack for plugging into an amp, mixer etc. Here is a link to the manual if you didn't get one:http://www.akaipro.com/ewi4000s/?tt=5 It is battery powered ( 4AA batteries ) so don't forget them. It can be powered by an optional MP9-II adapter (use the exact model ). It has a built in analog synth so if you set it up correctly you should get sound right out of the box. Hope this helps.
Yamaha DTXtreme IIS Drum Moduel repair
Listen to the output with headphones to check for noise.
OFTEN the output of a drum machine is CORRUPTED by an inadequate sound system. The waveforms generated by a drum machine tax the sound systems. A bass drum output can drive the speaker cone such that it goes beyond the linear range that the speaker and amplifier can handle and this appears as "noise". The noise may sound like a buzz or totally break up.
Turn the volume down and see if EXACTLY the same noise appears at low levels. If not, then saturation of the amp and speaker is likely. Continued use while it is doing that will often destroy the speaker.
1helpful
2answers
Problem using Kaoss Pad for synths.
Okay, maybe this is rude, but TOTALLY ignore Musicaldude's solution, if you haven't already found out the ugly way. Boosting the signal that goes into the KP will just make the input LED light up red and you'll hear digital clipping [gross] and eventually hit a ceiling of all-crappy-staticy-noise and no real guitar left. Having it in the FX loop, and the Headphone-out workaround are smart moves already, except the Headphone out adds noticeable noise/hum vs the usual outs. But to help close the gap between your guitar's volume and the miniKP's internal synths (and program 63 and 65's feedback noizes, which build up even louder than the synths) unplug one of the RCA plugs from the KP's OUTput, pick one, left or right, whichever. You'll notice this gives you a guitar volume boost. BUT its still not enough...the synths and 63 and 65's feedback are still speaker-blowingly loud. Check the manual, it says you can adjust the wet/dry volume by holding down Tempo and Preset A together, then turning the knob and picking 1 thru 99. Make sure you're on the synth setting you want to use already. Do this thing. Play the synth with your finger, while you lower the number with that knob. Stay around 50 if you've got the one RCA plug dangling, around 20 if both are in. Whatever you think matches your usual playing volume. When its where you like it, hold the A or B button (wherever you want to save this) down and click Hold, this will save it onto that preset button. Now from now on, NEVER use 63, 65, or the synths if you're on whatever preset you DIDN'T just save. i.e. If you chose preset B, from now on you can just tap preset B and it remembers your volume adjustment from before, voila, normal-volume touchpad synth. But go back to preset A for every other effect, or you'll barely be able to hear the FX. KORG should've given us more preset buttons to save onto. Godspeed. I've never seen this site before, but I have this pedal, and experienced the same b.s. myself. Now I'm down to one preset button and quick knob-turning. Whee.
Electronic drum kit, with USB out, problem
Sounds to me like you have the midi tracks outputting to the microsoft midi mapper or wavetable synth, which is built into the sound chip in your pc, and that this is conflicting with the mobilepre sound card - midi is just data, no audio, needs to drive some kind of synth. what you want to do is disable your internal sound card thru device manager, then just use the m-audio mobile pre as the input/output sound card in ASIO mode - you'll need to monitor via the headphone jack on the mobile pre or plug speakers into the line outs on the interface.
Then do tutorial 8 (in help files) on using soft synths - INSERT>SOFTSYNTHs creates a midi track and an audio track in a track folder.
Good luck.
The dude.
Top Propellerhead Music Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Propellerhead Music Expert? Answer questions, earn points and help others
