20 Most Recent Propellerhead Reason 5 Questions & Answers
REASONS 5 IN NOT WORKING ON MY WINDOWS 8 64BIT SYSTEM WHAT DO I DO?
Get an Apple
10/9/2014 2:25:08 AM • Propellerhead... • Answered on Oct 09, 2014
Reason 5 is not working on my laptop
Here is a link to Reason updates - note the 5.0.1 update - try that - you may have to register first. http://www.propellerheads.se/download/index.cfm?fuseaction=get_article&article=reason_updates
4/9/2014 3:34:36 PM • Propellerhead... • Answered on Apr 09, 2014
2answers
I can only hear the
yea im having the same issue.reason worked fine on my other comp.but as soon as i installed it on my laptop, i got this problem,it only plays the first instrument i load on my audio rack.if you toggle to the rear of the audio rack (press tab to view) the wires are not connected correctly.so i added a line mixer 6:2 and re routed the wires myself..and got it all working.
6/6/2013 9:44:05 PM • Propellerhead... • Answered on Jun 06, 2013
After installing reason 5 there is a prompt for what disc?
What exactly does it ask for?Did you try putting it back in?
3/6/2013 9:06:21 PM • Propellerhead... • Answered on Mar 06, 2013
When i play the keyboard
I'm not familiar with Reason 5, but many midi track recorders need each instrument assigned to different midi chanels to be heard back. Check the manual in how to assign the midi tracks. Also, the playback has to be through a unit that is multi timbrel capable. Good luck!
10/13/2011 3:30:02 PM • Propellerhead... • Answered on Oct 13, 2011
Whilst playing back a song reason stops for a
Make sure you do NOT have ANY antivirus/antispam/antiadware OR network links active. These high priority programs will steal the processor to do their scheduled tasks and your audio will get overrun. All such programs need to be removed or killed while running audio programs. Another problem can be caused if your disk is getting errors and it has to do retries to recover the data.
9/15/2011 3:35:30 PM • Propellerhead... • Answered on Sep 15, 2011
No playback coming out of
Make sure in the PC "control panel" Sounds and Devices all the sources and outputs are set to the hardware you are using instead of the default PC audio board. Also check they are un-muted and volumes are up.
5/11/2011 1:01:36 AM • Propellerhead... • Answered on May 11, 2011
The sound on my synths
okaye, i justt figured itt outt, hopefully you gett an email aboutt this postt...
so anywayz yo,
how many instruments you have hooked up to your mixer? thats the key, #1.
make sure you have atleast ATLEAST 2 mixers in your start up program, once you use the max output input for your original mixer, the next instrument patch you load will not be routed, (no more space), you'll have to route it manually (press Tab) *get familar with routing your own devices, for reverb/chorus and such,
this applies to everything about recieving sound from your project/keyboard. and just route your extra devices on the new mixer --they go up to 14 channels, i have like 22!
so thats my solution, hope itt applies.
Dre'
South Caro-line-em- up
~1~
4/13/2011 9:46:52 PM • Propellerhead... • Answered on Apr 13, 2011
Hello. I am having
I have the same problem, no word from Reason yet.
but what i keep doing is re-enter the program.
what i THINK the reason is, is that if you have soo many number of instrument programs hooked up to the mixer and what not, it blows reason 5's mynd!....
it has to be, because 3-4 yea your good, but 7 8 9 10, thats when i start getting problems! even fruity loops did a little better then this....(sad face). if i kno how to fix this foreal FOREAL, den ill post back..
Dre'
S.C
4/13/2011 9:37:00 PM • Propellerhead... • Answered on Apr 13, 2011
Hi, I have this problem with
check the instrument's "show programmer" tab at the bottom of every patch you plug in. if its on every single sound fx that you use, then it's something else, but for the most part, here is where your staccato comes in to play. tweak the OSC 1 2 etc, then the "portamento".
i hope this helps, i kno how ugly reason makes there products to not work for the user's advantage.
4/13/2011 9:33:10 PM • Propellerhead... • Answered on Apr 13, 2011
I just got the reason
Try getting the newest version of your OS. there are quite a few programs that are compatible with a certain operating system, but you need the latest edition to get them to run.
Hope that helps! Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/cameron_463100ffd54b591d
2/13/2011 6:44:59 PM • Propellerhead... • Answered on Feb 13, 2011
Peavey cs1000 x
The most likely case is that one of the main output transistors (if which there are many) is shorted. When the protect circuit senses DC on the final output, it will not allow the output relay to come on to protect the speakers from raw DC. With the power removed, you can check between each outputs Emitter and Collector and you will probably find close to zero ohms. From that point you need to unsolder each of the pins of the bad channel until you find the shorted device(s) and replace them.
2/7/2024 9:32:20 AM • Music • Answered on Feb 07, 2024
2answers
FRONTIOPAE what is this instrument unscrambled
'pianoforte'
1/17/2024 4:22:56 PM • Music • Answered on Jan 17, 2024
Looking for specific screw for a Crate and Barrel table
BREV. N. 838420
1/9/2024 8:32:24 PM • Music • Answered on Jan 09, 2024
I want to manually wire my z-560
1/4/2024 1:18:20 PM • Music • Answered on Jan 04, 2024
Propellerhead Reason 5 Logo
30 questions posted
Top Propellerhead Music Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Propellerhead Music Expert? Answer questions, earn points and help others
View Most Popular
Propellerhead Music
  • Propellerhead Music
Most Popular Question
only hear
  • Music
