SonicWALL Pro 2040 Firewall Logo
Posted on Jan 13, 2011
Our sonicwall 2040 is dead and our network is down
1 Related Answer
Anonymous
  • 80 Answers
  • Posted on Jun 02, 2010
SOURCE: how to block https (to block facebook) in
You will need to use a third party firmware or update your current firmware on the firewall
2helpful
2answers
I am forget the my sonicwall administrator password. how to login
Hello and Welcome to FixYa!
You can't login, all you can do is to reset the SonicWall. There is a small pinhole on the front panel, hold it for some time... that will boot it in a safe mode to reset it.
I hope you have a clear picture now.
Concerned, Nooh.
Sir I have SonicWall pro 2040, i hve already blocked the facebook but users can access the facebook from https://www.facebook.com, any way to block facebook from https
Just upgrade to the IPS (instrusion prevention subscription) for your 2040 and check Prevent ALL for HIGH, MEDIUM and LOW (LOW blocks Facebook like a champ). You'll find some other services blocked as well such as Terminal Services, but you can filter individual LOW priority attacks to allow those connections in (I recommend VPN for Terminal services anyway).
I actually was looking for a way to OPEN connections to Facebook while preventing LOW priority attacks and found your post.
-lt
www.thornedigital.com
1helpful
How to block https (to block facebook) in sonicwall PRO 2040 Enhanced
1helpful
2answers
I am using Sonicwall Pro 2040. I am trying to connect Sonic Wall gateway but it is asking for pre-shared key instead of user and password please help me. regards pratap
pre-shared key is a must for connectivity. only after inputting this, you would be prompted with user id & password, if configured to.
I have a sonicwall pro 2040 and while the firewall rules look correct, I cannot get traffic from the WLAN to the LAN, nor from the WLAN to the WAN.
SonicWALL Wireless Configuration Wizard To access SonicWALL’s Wireless Configuration Wizard, log on to the SonicWALL router, then click the Wireless button found within the left navigation bar of SonicWALL’s Web-based management interface. The Wireless Status page will be displayed. Click the Wireless Wizard button that appears toward the top-right of the screen.
The SonicWALL Wireless Configuration Wizard will appear. Click the Next button to proceed with the wireless administration utility.
The wizard’s first step will appear as seen in Figure A. Step one addresses wireless local area network (WLAN) network settings. You must specify the WLAN IP address and subnet mask before continuing. In addition, a checkbox is provided for enabling Windows networking support between the wired local area network and the WLAN. Be sure to check the box to enable communication between the LAN and WLAN. Then, click Next.
Step two requires setting the Service Set ID (SSID), radio mode, country code and channel. The SonicWALL wizard provides a blank field for specifying the SSID. The default SSID is sonicwall. Consider changing the SSID to a value that reveals nothing about the organization or office in which it is deployed. I typically deploy SSIDs as HomeNetwork and BusinessNetwork, as doing so provides potential hackers with less information about a network (particularly in more heavily populated areas such as apartments and office parks).
On most SonicWALL routers, including the popular TZ 170 wireless model, three radio modes are available: 2.4GHz 802.11 b, 2.4GHz 802.11g or 2.4GHz 802.11g and b Mixed mode. Using the provided drop-down menu, select the mode you wish to use within your organization.
The last item to configure within Step 2: WLAN 802.11b/g Settings is the channel. Channels one through 11 are available options. Or, AutoChannel is an alternative choice and, in fact, the default. Choosing AutoChannel allows the wireless network equipment to automatically negotiate the best channel settings. Once the channel is specified, clicking Next continues to the next step.
Step 3: WLAN Security Settings enables configuring one of three security modes for the
SonicWALL wireless router. The three security mode choices are:
  • WiFiSec VPN Security – The default selection, WiFiSec VPN Security creates an IPSec-powered VPN over which the wireless traffic travels.
  • WEP + Stealth Mode – Utilizes Wired Equivalent Protection (WEP) to secure wireless communications.
  • Connectivity – Implements wireless communications featuring no encryption or access controls.
When selecting WiFiSec VPN Security and clicking Next, the Step 4: WiFiSec – VPN Client User Authentication page appears. This step helps create a user name and password for a new user with VPN client access privileges. The WLAN WiFiSec security setting will enable the SoniCWALL Group VPN feature. If you wish to edit user privileges, you can log on to the SonicWALL router’s Web-based administrative interface and edit user permissions by clicking Users | Settings.
After a user name and password are supplied, click Next to proceed to the wizard’s fifth step. The Step 5: Wireless Guest Services screen allows you to enable guest wireless access while also specifying the guest account name, password and account and session lifetimes.
Once these values are supplied, click Next to view a Wireless Configuration Summary. Clicking Apply prompts the SonicWALL Configuration Wizard to apply the settings and configuration parameters you’ve entered into the wizard. When the wizard completes, a confirmation page should then appear (with a Finish button being the only available option).
Unable to reach firewall periodically
If you are using the firewall as the DHCP server, you may need to check the DHCP lease period on the firewall & increase it if required.
Private network > VPN > network firewll > priv net
Add a static route on the Sonicwall 2040 : 192.168.1.0/24 with the RV082 as gateway (the ip of the network shared between the RV082 and the Sonicwall)
Another solution is to enable NAT on RV082 for 192.168.1.0/24 network. Routing is preferable.
1helpful
How to switch over opt port to wan port in sonicwall
In order to do this, you will need to order the sonicwall OS enhanced. You can do this from your mysonicwall.com account.
After you upgrade the firmware, you will have a network load balancing option. you can then set the primary and secondary connections and use the active/passive failover option that is provided.
Yahoo and ims installing
when u go to internet explorer it wont allow u to enter because u r restricted by firewall one u allow the yahoo by giving permission to ur firewall otherwise u disable the firewall u can
2answers
Sonicwall 330 pro
If it has a reset button, you'd want to try holding it down until you see the lights flash to let you know the reset completed. It should be fine after that, unless the power surge toasted it for good.
Top SonicWALL Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a SonicWALL Computer and Internet Expert? Answer questions, earn points and help others
