20 Most Recent SonicWALL SSL-VPN NetExtender Adapter Questions & Answers
I tried to install NetExtender
In Windows your security settings need to be set to accommodating this installation you can find the security settings for IE8 by going to tools then internet options set your security to low from your question it reads that you have done this already my research bring me to this option please read below.
Article Applies To:
SonicWALL SMB SSL-VPN Appliances and Software: SMB SSL-VPN 2000, SMB SSL-VPN 4000, NetExtender
Firmware/Software Version: 2.5 or higher
Problem Definition:
When installing NetExtender on any supported Windows operating system, the error "Failed to install NetExtender, the installation has been rolled back" may be observed, especially when the operating system is installed on a drive other than the default. This issue is resolved by upgrading the SSL VPN 2000 or 4000 appliance to firmware version 2.5 or higher and making another installation attempt.
Resolution or Workaround:
For each of the following possible causes of this behavior, an explanation, workaround, or solution is provided:
  • User does not have administrative privileges. With 2.5.x.x firmware and above, administrative privileges are required for initial installation only, previous versions require administrative privileges for each update.
  • Browser security settings. Add https://IP-or-DomainName to trusted sites, and set trusted sites security level to LOW.
  • Popup blocker. Disable all third party popup blockers.
  • Anti-virus or anti-spyware. Temporarily disable all third party anti-virus or anti-spyware solutions.
Source: SSL VPN 2000/4000 2.5 Release Notes this has been copied from doing my research this is not my material but a help post from another source. Thanks for using FixYa! do not forget to vote for me. John
3/12/2011 10:42:43 AM • SonicWALL... • Answered on Mar 12, 2011
I changed my password before. But I forgot it now. How can I access my password before?
What password you are talking about pc network Or any other
3/13/2015 4:36:36 AM • SonicWALL... • Answered on Mar 13, 2015
0answers
Strange noise
Sounds (pun intended) like one of the cooling-fans has worn-out bearings, and is "screeching", just before it totally freezes-up, and dies, and causes your SonicWall to overheat.
7/29/2014 3:53:48 AM • SonicWALL... • Answered on Jul 29, 2014
Cannot access blocked website
Ask your "system administrator" to UNBLOCK that site.
7/29/2014 3:09:01 AM • SonicWALL... • Answered on Jul 29, 2014
UPNP over sonicwall
For "security" reasons, you should not all UPNP traffic from "outside" of your network to enter your "internal" network. Block it.
7/29/2014 2:58:47 AM • SonicWALL... • Answered on Jul 29, 2014
Remove pc performer from my computer
Hi you can remove the PC Perfomer using the software Ccleaner. CCleaner 4 09 4471 select tools and uninstall the PC Performer, if it doesn't uninstall then select delete entry. Also Ccleaner makes your computer faster by removing temporary files/cleaning registry. Hope this helps.
5/30/2014 6:08:17 AM • SonicWALL... • Answered on May 30, 2014
Hack the sonic wall
Hacking is a broad term and there are many attack vectors which you can use. If you do not truly understand that then you will not be cracking a firewall. You need a method of attack, recon it and search the vulnerabilities.
4/28/2014 7:07:17 PM • SonicWALL... • Answered on Apr 28, 2014
How can I access the password of my pldt dsl wifi?
Better contact your network provider
or you have to crack your network your own way if you want
the providers could help you otherwise
4/7/2014 5:17:50 AM • SonicWALL... • Answered on Apr 07, 2014
Get bsnl internet settings sony xperia
The high-level answer is to get the login parameters and internal IP for the Sonicwall, get the Internet parameters for your new ISP, and then log into the Sonicwall device, go to Networking-> Interfaces, and configure the WAN adapter with those settings.
1/31/2014 2:27:29 PM • SonicWALL... • Answered on Jan 31, 2014
0answers
Password hack
Be the first to answer 1/25/2014 8:36:43 AM • SonicWALL... • Posted on Jan 25, 2014Be the first to answer
Not able to ping 64.16.223.163
This is not a valid address or the server that is suppose to be connected to that address no long exists.
1/11/2014 8:09:29 AM • SonicWALL... • Answered on Jan 11, 2014
0answers
Airg divas log in
Be the first to answer 11/12/2013 11:41:15 PM • SonicWALL... • Posted on Nov 12, 2013Be the first to answer
0answers
Www rediff com
Be the first to answer 11/12/2013 10:19:23 AM • SonicWALL... • Posted on Nov 12, 2013Be the first to answer
Computers & Internet Logo
4 questions posted
Top SonicWALL Computers & Internet Experts
Ekse
Are you a SonicWALL Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • SonicWALL Computers & Internet
Most Popular Question
tried install netextender
  • Computers & Internet
