SonicWALL Pro 2040 Firewall Logo
Question about SonicWALL Pro 2040 Firewall
How to block https (to block facebook) in sonicwall PRO 2040 Enhanced
Posted by balaji242 on
Anonymous
  • 80 Answers
You will need to use a third party firmware or update your current firmware on the firewall
Posted on Jun 02, 2010
1 Related Answer
Anonymous
SOURCE: Sir I have SonicWall pro 2040,
Just upgrade to the IPS (instrusion prevention subscription) for your 2040 and check Prevent ALL for HIGH, MEDIUM and LOW (LOW blocks Facebook like a champ). You'll find some other services blocked as well such as Terminal Services, but you can filter individual LOW priority attacks to allow those connections in (I recommend VPN for Terminal services anyway).
I actually was looking for a way to OPEN connections to Facebook while preventing LOW priority attacks and found your post.
-lt
www.thornedigital.com
Posted on May 26, 2011
I have restricted access to facebook on my network using sonicwall NSA 240 firewall by adding www.facebook.com in restricted domains. if someone tries to access it directly he is not getting the site. But...
Isn’t the internet great?
Well the way that these filters work is that they look for the EXACT address: www.facebook.com. To fix this you’ll want to add https://www.facebook.com and http://www.facebook.com. This will help the filter to see all combinations and block them all.
Let me know how this turns out!
2helpful
2answers
I am forget the my sonicwall administrator password. how to login
Hello and Welcome to FixYa!
You can't login, all you can do is to reset the SonicWall. There is a small pinhole on the front panel, hold it for some time... that will boot it in a safe mode to reset it.
I hope you have a clear picture now.
Concerned, Nooh.
4answers
When i try to go on the webpage it is telling me that it is blocked by sonicwall content filter
Sonicwall content filter is a product for enterprises to block employees from reaching external websites.
Sadly you will not be able to get there without breaking company policy :(.
Sir I have SonicWall pro 2040, i hve already blocked the facebook but users can access the facebook from https://www.facebook.com, any way to block facebook from https
-lt
1helpful
I forget my sonicwall admin password how will reset this password
If the SonicWALL's admin password is lost, there is no backdoor or other mechanism to bypass the administrator login. Please note that prefs files do not contain the admin name and password. So if you reset the firmware and import a current prefs file, you can gain access using the default login credentials ('admin' & 'password'). Without a current prefs file, you must reset the firmware and configure from scratch.
For models running SonicOS (Enhanced or Standard), you can reboot to factory defaults. This resets all settings including the admin name, password and LAN IP address. Import the current prefs file. The configuration is restored and use the defaults 'admin' and 'password' to login.
For models running Firmware 6.X, you must reset the firmware (wipe and upload using the reset procedure). Import the current prefs file. The configuration is restored and use the defaults 'admin' and 'password' to login. The 'Reset to Factory Defaults' button does not reset the admin name, password or LAN IP address for these models
1helpful
2answers
I am using Sonicwall Pro 2040. I am trying to connect Sonic Wall gateway but it is asking for pre-shared key instead of user and password please help me. regards pratap
pre-shared key is a must for connectivity. only after inputting this, you would be prompted with user id & password, if configured to.
Unable to reach firewall periodically
If you are using the firewall as the DHCP server, you may need to check the DHCP lease period on the firewall & increase it if required.
Private network > VPN > network firewll > priv net
Add a static route on the Sonicwall 2040 : 192.168.1.0/24 with the RV082 as gateway (the ip of the network shared between the RV082 and the Sonicwall)
Another solution is to enable NAT on RV082 for 192.168.1.0/24 network. Routing is preferable.
Yahoo and ims installing
when u go to internet explorer it wont allow u to enter because u r restricted by firewall one u allow the yahoo by giving permission to ur firewall otherwise u disable the firewall u can
Top SonicWALL Computers & Internet Experts
Marvin
Marvin
Are you a SonicWALL Computer and Internet Expert? Answer questions, earn points and help others
