Question about SonicWALL TZ 170 Firewall
Sonicwall Safe mode Problem
Im using Sonicwall TZ180, my sonicwall suddenly become on the safe mode screen. I cant return it back to my current setting. Is there any body experience this things and can help me to solve this problem.
Thanks in advance
Posted by bjhay28 on
Anonymous
    Problem Solver:
  • 7 Answers
How do I access the SafeMode menu?
In emergency situations, you can access the SafeMode menu by holding in the Reset button on the back
of the TZ 180 (it’s the small pinhole button located to the left of the Console port) for 12-14 seconds until
the ‘Test’ light begins flashing yellow. When the SonicWALL is booted into the SafeMode menu, assign a
workstation a temporary IP address of 192.168.168.200 and attach it to a LAN interface on the TZ 180
Then, using a modern web browser (Microsoft IE6.x, Mozilla 1.4+), access the special SafeMode GUI
using the device’s default IP address of 192.168.168.168. You will be able to boot the device using a
previously saved image, or you can upload a new version of firmware with the ‘Upload New Firmware’
button.
Posted on Apr 13, 2009
Downlaod tz180 firmware
You need to login to mysonicwall.com to download this firmware. Did you create an account at mysonicwall.com and register this SonicWALL in your account? If you haven't you will need your device serial number and activation code, both of which are printed on the back of your firewall.
2helpful
2answers
I am forget the my sonicwall administrator password. how to login
Hello and Welcome to FixYa!
You can't login, all you can do is to reset the SonicWall. There is a small pinhole on the front panel, hold it for some time... that will boot it in a safe mode to reset it.
I hope you have a clear picture now.
Concerned, Nooh.
1helpful
Wife is patient in local hospice. Has her own laptop and been given permission to acccess local wifi. Local service identified as Sonicwall. When we enter the password key (given to us by hospice staff)...
The inability of a client running Windows Vista to connect with a SonicPoint or any SonicWALL firewall (UTM) appliance running SonicOS Standard firmware is caused by a lack of a correct association on the SonicWALL between the computer running Windows Vista and its assigned IP address. Follow these steps to work around the issue by editing the System Registry:
WARNING: Exercise extreme caution when modifying the System Registry. Incorrect modifications could lead to an inability to boot your system. It may become necessary to completely reinstall your operating system.
  1. Click the Start button.
  2. Select All Programs > Accessories.
  3. Right click Command Prompt and click Run as administrator.
  4. Type regedit.exe and press enter.
  5. Go to the following location: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters
  6. Right click this entry and select New Dword.
  7. Rename the new entry ArpRetryCount (leave it set to 0 by default).
  8. Restart the computer.
  9. Reassociate with the SonicWALL. You should notice a successful connection.
Please print this out if possible, you may want to take your computer to a local repair shop to make this change if your not comfortable.
1helpful
I need to add an ip range to my sonicwall tz 170
This is not directly possible to do with a TZ170 as the device will only allow configuration for 1 static or dynamic IP at a time for the WAN port.
However this being the case, I suggest setting the SonicWALL up as a perimeter firewall and place devices that require the other public IPs form the additional IP range behind the TZ170. Basically the SonicWALL becomes the gateway for the other IPs needed as long as the range of the IP block is contiguous.
This would involve using the 4 ports of the LAN on the back of the TZ170 to connect directly to the other devices or if it is more then 4 devices, using a switch connected to the LAN side of the SonicWALL to provide connectivity to the multiple devices behind it. Most TZ170 are licensed for 10 connections on the LAN side and if you require more then 10, additional licenses will need to be purchased.
I would be careful pushing too much traffic through a TZ170 as it is designed for Small Business use and will quickly become overloaded with too much traffic causing high latency/traffic bottlenecks and in extreme cases connections being dropped. This is especially true for multiple VPNs.
Sonic wall 170 fequently goes on safe mode
Upgrade the firmware & see if u have all the security bundles upto date.
I have a sonicwall pro 2040 and while the firewall rules look correct, I cannot get traffic from the WLAN to the LAN, nor from the WLAN to the WAN.
SonicWALL Wireless Configuration Wizard To access SonicWALL’s Wireless Configuration Wizard, log on to the SonicWALL router, then click the Wireless button found within the left navigation bar of SonicWALL’s Web-based management interface. The Wireless Status page will be displayed. Click the Wireless Wizard button that appears toward the top-right of the screen.
The SonicWALL Wireless Configuration Wizard will appear. Click the Next button to proceed with the wireless administration utility.
The wizard’s first step will appear as seen in Figure A. Step one addresses wireless local area network (WLAN) network settings. You must specify the WLAN IP address and subnet mask before continuing. In addition, a checkbox is provided for enabling Windows networking support between the wired local area network and the WLAN. Be sure to check the box to enable communication between the LAN and WLAN. Then, click Next.
Step two requires setting the Service Set ID (SSID), radio mode, country code and channel. The SonicWALL wizard provides a blank field for specifying the SSID. The default SSID is sonicwall. Consider changing the SSID to a value that reveals nothing about the organization or office in which it is deployed. I typically deploy SSIDs as HomeNetwork and BusinessNetwork, as doing so provides potential hackers with less information about a network (particularly in more heavily populated areas such as apartments and office parks).
On most SonicWALL routers, including the popular TZ 170 wireless model, three radio modes are available: 2.4GHz 802.11 b, 2.4GHz 802.11g or 2.4GHz 802.11g and b Mixed mode. Using the provided drop-down menu, select the mode you wish to use within your organization.
The last item to configure within Step 2: WLAN 802.11b/g Settings is the channel. Channels one through 11 are available options. Or, AutoChannel is an alternative choice and, in fact, the default. Choosing AutoChannel allows the wireless network equipment to automatically negotiate the best channel settings. Once the channel is specified, clicking Next continues to the next step.
Step 3: WLAN Security Settings enables configuring one of three security modes for the
SonicWALL wireless router. The three security mode choices are:
  • WiFiSec VPN Security – The default selection, WiFiSec VPN Security creates an IPSec-powered VPN over which the wireless traffic travels.
  • WEP + Stealth Mode – Utilizes Wired Equivalent Protection (WEP) to secure wireless communications.
  • Connectivity – Implements wireless communications featuring no encryption or access controls.
When selecting WiFiSec VPN Security and clicking Next, the Step 4: WiFiSec – VPN Client User Authentication page appears. This step helps create a user name and password for a new user with VPN client access privileges. The WLAN WiFiSec security setting will enable the SoniCWALL Group VPN feature. If you wish to edit user privileges, you can log on to the SonicWALL router’s Web-based administrative interface and edit user permissions by clicking Users | Settings.
After a user name and password are supplied, click Next to proceed to the wizard’s fifth step. The Step 5: Wireless Guest Services screen allows you to enable guest wireless access while also specifying the guest account name, password and account and session lifetimes.
Once these values are supplied, click Next to view a Wireless Configuration Summary. Clicking Apply prompts the SonicWALL Configuration Wizard to apply the settings and configuration parameters you’ve entered into the wizard. When the wizard completes, a confirmation page should then appear (with a Finish button being the only available option).
How to routing router static ip address and local
Use the Sonicwall configuration wizard..
Please find below is to configure what ever you want.
Setup Wizard - This wizard will help you quickly configure the SonicWALL to secure your Internet connection. Once completed, you can use the SonicWALL Web Management Interface for additional configuration.
Registration & License Wizard - This wizard will help you register you and your firewall with mysonicwall.com and obtain licenses for additional Security Services features.
PortShield Interface Wizard - Segment and configure the integrated managed LAN switch of the SonicWALL.
Public Server Wizard - Quickly configure your SonicWALL to provide public access to an internal server.
VPN Wizard - Create a new site-to-site VPN Policy or configure the WAN GroupVPN to accept connections from the SonicWALL Global VPN Client
Thanks
2answers
I want to create site to site vpn with sonicwall tz170+ 2003serv
Complete documentation is available on the below link
http://www.sonicwall.com/us/support/3134.html#heading_3139
2answers
Printer Setup & Support Call 1-805-225-6690 We will Help to Fix issue
Not sure if you've done this already or not, but I would suggest installing the printer manually as a local printer, and create a TCP/IP port that points at the IP of the Printer. Rudimentary way to go, but should help.
-Backu
Can not connect to PPPOE DSL
Is there a reason why the Sonicwall needs to do the PPPOE auth? You should be able to let the modem do the PPPOE connection and have the Sonicwall behind it. The Sonic wall will get a private IP address. Andy
SonicWALL TZ 170 Firewall Logo
Top SonicWALL Computers & Internet Experts
Ekse
Are you a SonicWALL Computer and Internet Expert? Answer questions, earn points and help others
