The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa ( http://picasa.google.com )
Hi, Here is a tip that may help you with your problem....
I found out that with my cameraI needed to transfer the pictures within the camera to the card and them fromthe card to the computer... The process for your camera may not be exactly the same, but should be similar.
Press 'Menu/Ok' button, then select left/right arrows to select 'Setup' sub-menu,then select 'Format' menu item with up/down arros and press 'Menu/Ok' button. Select 'Yes' and press 'Menu/Ok' again. Don't forget to download important images to PC before doing this. ALL images from memory card will be DELETED by formatting.
1. Clean the battery contacts in the camera with a cotton swab lightly dampened with rubbing alcohol.
2. Be sure the batteries seat properly in the camera.
I am having the same problem. By all indications it looks like the motor controller is the problem. Everything else works OK. I am pulling the controller tomorrow and replacing. If that doesn't work I am junking it.
The unit has stopped reading discs. I suggest taking the lid off and cleaning the laser lens with a cotton bud with a little Windex , then give it a gentle polish to be sure no residue smearing is left. If that does not fix it, check to see what actually happens when you load a disc. Does the transport fully engage and clamp the disc correct into the chucking assembly. Let me know how you got on:)
