Ryobi Multi-Volt Battery Charger Logo
Posted on Jan 12, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Will 14.4 volt charger charge 18 volt battery ryobi
Anonymous
Level 3:
  • Master 1,514 Answers
  • Posted on Jan 12, 2011
Anonymous
Master
Level 3:
Answers
1514
Questions
Helped
332235
Points
3516
I'm afraid not. It will damage the battery if you try. You'll need to get the correct charger.
Ryobi 18 volt charger shows fully charged.
Question moved to a Ryobi category from MISC.
If they both show charged, they are unlikely to be incorrect. You can test the contacts of the batteries with a test meter, and you can also test the charger output.
If they don't work in a tool, the tool may have failed. Having said that, they do appear to have some history of this. Check out the videos.
https://www.google.com/search?q=Ryobi+18+volt+charger+shows+fully+charged
1helpful
2answers
Can i charge a 18volt ryobi battery on a 14.4volt charger
you can but it will take longer to charge and prob will be at 16 volts give or take 1 volt.
I have 2 ryobi 18 volt one + batteries won't charge, blinks red. I have 2 chargers, same for both. 65 degrees here so not too cold.
Just a thought, lithium batteries wont charge in Ryobi's old chargers. I upgraded my batteries but not the charger until I found this out.
2answers
I currently live in Europe and have a Ryobi CHP-1802 drill with an 18 volt Li-Ion battery. The charger is a Ryobi BCL-1800 220 Volt, 50 Hz. I am moving back to the United States and want to keep thi
After looking at the manual for your charger, it looks like most of the Ryobi chargers like the P113, P114, P117, P118 will charge your battery. The connector on the battery looks the same as the P103 and P104 used here in the U.S.
2answers
2answers
I have a ryobi 18V battery and the only charger I have is a ryobi 14.4V. Can I charge the 18V battery on that charger?
Hello, unless the charger specifies that it charges 18 volt, it will only charge a 14.4v properly. If the battery fits the charger physically, then the most you might get an 18v to charge at is 15 or 16 volts. Your battery life will be shorter and you might damage the charger. I hope this helps.
2helpful
1helpful
Charging
Negative partner, you can try all day everyday but 12 v is 12v and 18 v is much more. its just not gonna supply enough juice to charge the battery. the most youll ever charge it is 12 v... sorry.
1helpful
2answers
Can a bad ryobi 18 drill ruin a new 18volt ryobi battery
If the drill has a short in it, then yes, it could short the battery out. Probably in the trigger switch.
Top Ryobi Drills Experts
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
Are you a Ryobi Drill Expert? Answer questions, earn points and help others
