Question about Ryobi Two 18V Lithium-Ion Batteries + Lithium-Ion Charger Upgrade Combo Pack
I just bought an 18 volt Ryobi trimmer/edger. Charging the battery was easy and quick with the flashing lights letting me know what was going on. Once charged, should I leave the battery on the plugged in charger or take the battery off the charger and unplug the charger?
Posted by pdborton on
David Ford
  • 2,176 Answers
Most recommend taking the battery off the charger and you don't have to unplug the charger all the time.
Posted on Aug 28, 2011
If the battery charger light is red, does it mean it's not charging?
Red normally means it is not done charging yet. It will turn green or go out when it is completely charged.
Jan 23, 2016 | Ryobi Garden
Ryobi problems
Check to make sure you don't have a staple stuck under the hammer. If the spring feed is working, then something is keeping the staples from sliding under the hammer. Can you hear the hammer hitting? Does it leave an impression on the wood?
Jul 29, 2014 | Ryobi Lithium Ion 18 Volt 18v Cordless...
How do I get the old line trimmer spool off of my Ryobi 18 volt cordless trimer
When looking at the head, you will see to two gray rectangle pieces. Press them both at the same time between your thumb and forefinger and then pull. It should come unlatched and reveal the line spool on the inside
Jul 25, 2014 | Ryobi Lithium Ion 18 Volt 18v Cordless...
Why is my ryobi 18 volt trimmer smoking? I have had this 2.5 years and using it on lawn edges only.
The motor is failing. Most likely the brushes have failed, but this is all sealed and they cannot be replaced alone.
Jun 10, 2014 | Ryobi 18 Volt 18v Cordless String Trimmer...
Electric ryobi weedeater with good battery won't start
Ryobi Trimmers unscrew halfway down the shaft (so it fits in the box). If this gets loose, the trimmer will stop working. Simply tighten the connection between the upper and lower half.
Mar 31, 2013 | Ryobi Lithium Ion 18 Volt 18v Cordless...
Cross section of ryobi 18v trimmer
the wiring maybe disconnected, either at the switch or down near the head of the trimmer
Sep 09, 2012 | Ryobi Lithium Ion 18 Volt 18v Cordless...
Bought unit last year...when charging battery for 1st time this year red goes to green fairly quickly but only lasts a few minutes when using trimmer
sounds as though the battery needs replaced, can check and see if it has a warranty on the battery. Hope this helps Tim
May 01, 2011 | Worx GT WG150 10 in. 18 Volt Cordless...
Ryobi Two  18V Lithium-Ion Batteries + Lithium-Ion Charger Upgrade Combo Pack Logo
304 people viewed this question
Top Ryobi Drills Experts
JOHN LAPIER
Marvin
Marvin
Are you a Ryobi Drill Expert? Answer questions, earn points and help others
