Canon PowerShot A590 IS Digital Camera Logo
Anonymous Posted on Dec 27, 2010
How to set self timer? - Canon PowerShot A590 IS Digital Camera
Anonymous
Level 2:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
  • Expert 198 Answers
  • Posted on Dec 27, 2010
Anonymous
Expert
Level 2:
Mentor:
Answers
198
Questions
Helped
24624
Points
563
Hi.
1. On the outside of the cameraPress the 'function set' button marked How to set self timer? - chas6_15.jpg.
2. Use the 'up'/'down' buttons to select 'Drive Mode' chas6_13.jpg in the display.
3. Use 'left' / 'right' buttons to change the self-timer mode.
4. Choose the timer delay or seHow to set self timer? - chas6_14.jpgc="/uploads/images/chas6_14.jpg" alt="chas6_14.jpg" class="h_mi" />, after which pressing the 'Disp.' button will allow you to set the delay and number of shots.
5. Press the 'function set' button again to start the timer.
Hope this helps!
Testimonial: "Thank you!!! You are awesome and i appreciate it!"
So I have an EOS Rebel Xsi, and it has been working perfectly for the last couple of months. I turned it on and tried to take a picture in MF, but then a yellow light on the front starts flashing and...
Sounds like the self timer was accidently set.
Description
Using the Self-timer on the EOS REBEL T3i.
Solution
The self-timer is useful when you want to photograph yourself or prevent camera shake caused when the shutter is released.
1. Set the power switch to <ON>.
2. Press < > button.
3. Press <Cross Keys> to select the desired self-timer, then press the <SET> button.
: 10-sec. self-timer (The remote control can also be used.)
: 2-sec. self-timer
: 10-sec. self-timer plus continuous shots. After selecting , press <Cross Keys> to set the number of multiple shots (2 to 10) to be taken with the self-timer.)
4. Look through the viewfinder, focus the subject, then press the shutter button completely.
  • You can check the self-timer operation with the self-timer lamp, beeper, and countdown display (in seconds) on the LCD monitor.
  • Two seconds before the picture is taken, the self-timer lamp will stay on and the beeper will sound faster.
Attention:
With [ ], the interval between the multiple shots may be prolonged depending on the shooting functions settings such as the image-recording quality or flash.
NOTE:
  • After taking self-timer shots, you should check the image for proper focus and exposure.
  • If you will not look through the viewfinder when you press the shutter button, attach the eyepiece cover. If stray light enters the viewfinder when the picture is taken, it may throw off the exposure.
  • When using the self-timer to photograph only yourself, use focus lock on an object at about the same distance as where you will stand.
  • To cancel the self-timer after it starts, press the < > button.
1helpful
How do I set the self timer on my cannon a560 camera?
Press the self-timer button to cycle through self-timer settings. The rectangle indicates normal shooting, the clock indicates self-timer. Depending on the shooting mode, you may also see overlapped rectangles for continuous shooting.
To change the delay time, select [Self-timer] from the Recording menu.
The self-timer button is the same as the down-arrow on the circular multi-selector, marked with a clock.
I need help with setting the self timer on the Olympus Camedia c-700 camera. Can't figure how to do it with the menu. Any help would be greatly appreciated, Thanks
the self timer usually works like this.
find the self timer setting and set it to 5 or 10 seconds.
then exit the menu and click the button that you normally press to take photo. the self timer will start automatically and the picture will be taken after 5 or 10 seconds (depending on what you set).
note that the self timer will be reset to off after this.
Press the the stopwatch symbol (Down button) repeatedly to select self-timer. Custom timer parameters can be defined by pressing MENU and selecting self-timer settings with FUNC.SET key (central button).
4helpful
How to use the timer on a sony cyber shot 7.2mp digital camera
On your Cyber-shot DSC-W55 locate the control button:
32864f9.jpg Using the self-timer
Press cd9ebdc.jpg on the control button repeatedly until the desired mode is selected.
Conditions of the self-timer lamp:
(No indicator): Not using the self-timer
fc274e6.jpg: Setting the 10-second delay self-timer (picture is taken after 10 seconds)
996d00d.jpg: Setting the 2-second delay self-timer (picture is taken after 2 seconds)
Press the shutter button, the self-timer lamp flashes, and a beep sounds until the shutter operates.
Hope this helps.
Thank you.
1helpful
I cant figure out how to set the self timer on this camera
If you press the left < button on the camera before you take a picture you will have the option to set the self-timer. The options that you can choose are: 1. Single shot; 2. Continuous shot; 3. Self-timer (10 sec) / Remote control; 4. Self-timer (2 sec); 5. Self-timer (10 sec): Continuous (2 - 10 shots).
Hope this helps!
Please rate!!
Cheers
Self timer set up
1. Secure the camera to a tripod or place it on a stable surface.
2. Rotate the mode dial to [S], [P], [PICT], [AV], or [M]
3. Press the Power button turn on the Camera.
4. Press arrow [>] .
5. Use up arrow or down arrow to select the desired self-timer mode.
6. Compose your scene and press the shutter button.
  • The self-timer function is activated.
  • The photograph is then taken after the preset time.
  • To cancel the self-timer at any time, press the shutter button.
After one shot is taken, the self-timer mode is turned off.
If you wish to take another image using the self-timer, repeat these steps.
1helpful
Does camera have timer
Putting Yourself in the Picture The Self Timer creates a 10-second delay between the time you press the Shutter button and the time the picture is taken. 1 Place the camera on a flat surface or use a tripod. 2 In any Still mode, press the Self Timer button. The Self Timer icon appears in the status area. 3 Compose the scene. Then press the Shutter button half-way and hold to set the exposure and focus, then press the rest of the way down. Move so that you are in the scene. The Self Timer light blinks slowly for 8 seconds (then quickly for 2 seconds) before the picture is taken. The camera "clicks" when the picture is captured. To turn off the shutter sound, see page 64. The Self Timer turns off after you take the picture or if you change modes. To cancel the Self Timer before the picture is taken, press the Self Timer button. (The Self Timer setting remains active.) To turn off the Self Timer, press the Self Timer button twice.
Self Timer
Once you have the self-timer set up, press the shutter release button to activate it.
2helpful
Setting the camera timer
by the way in setting the timer for your camera here is what you are going to do...
-turn the camera on
-set the camera in recording
-press the Right Button beside the menu button (the incomplete circle)
-and then you will see that there will an icon showing in the left side part of the screen of the camera.
Selecting the self-timer
1. Rotate the MODE DIAL to select a RECORDING mode with the exception of VOICE RECORDING mode.
2. Press the SELF-TIMER button until the desired mode indicator displays on the LCD monitor.
A 10 second, 2 second or double self-timer icon appears on the LCD monitor. In Movie Clip mode, only the 10-second self-timer will work.
•2SEC self-timer (icon of incomplete circle with 2S)
: Pressing the shutter button will allow an interval of 2 seconds before the image is
taken.
•10SEC self-timer (incomplete circle)
: Pressing the shutter button will allow an interval of 10 seconds before the image is taken.
•Double self-timer (double incomplete circle)
: A picture will be taken after about 10 seconds and 2 seconds later a second picture will be taken. When using the flash, the 2-second self-timer may be delayed for longer than 2 seconds depending on the flash charge time.
3. When you press the SHUTTER button, the picture will be taken after the
specified time has elapsed.
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
