Your Nintendo Wii can not properly read some portions of your Game Disk. The probable reasons are dirt on the lens or CD, or scratches on the CD. Try cleaning the CD using a soft cloth and clean the lens of your Wii console using a Lens Cleaner.
You can rate my answer if you appreciate it. Thanks!
Your WII is having trouble reading disks? Try using a dvd/cd ROM cleaner disk. Run the cleaning disk in the WII a couple of times and try inserting your game again. If it still does not read the disk, try cleaning the game disk itself with a lint free cloth and alcohol. make sure to dry the disk completely and never wipe in a circle. If this does not solve the issue, try playing the disk in another WII to figure out if the problem is isolated to the disk itself. If the disk plays in another WII, then contact the manufacturer and send the console in for repair.
I have had that same problem with a game of mine. I believe that something may have gotten on the disk. Try to clean the disk and then try again. If it still won't work, you probably need to replace it.
If the Wii is having trouble with a disk, it means there's either a problem with the disk or the Wii. If your Wii can't read any disks then you'll want to contact Nintendo. Otherwise you need to investigate your disk.
If you hold the bottom side of the disk to the light you should be able to see if there's a smudge or scratch. If it's a smudge, cleaning the disk will often fix the problem. Use the microfiber cloths used to clean eyeglasses or, short of that, a tissue. Just rub the smudged spot. (When using a tissue I generally steam up the spot with my breath first.) If the disk looks good, put it back into the Wii and see what happens.
A scratch is more problematic. If it's a game you just bought, try exchanging it where you bought it. Otherwise you can try polishing out the scratch.
Some older Wii units also have trouble with dual layer discs, If your Wii is having trouble reading a dual layer disc you can try Nintendo's Wii lens cleaning kit. And also you can try to use a different disk to check if your system will be able to read it. then try the Wii Fit Plus If after all that, your Wii still can't read the disc, it's probably just a bad disc.
If the wii is standing up, try laying it flat. Make sure its not upside-down when you do this. If this doesn't work, try the official lens cleaner disk.
If none of that works, i hope its under warranty. If not, we can get into taking your wii apart and cleaning the lens. If that doesn't work you probably need to either replace the laser assembly or recalibrate it. I don't suggest trying to do the calibration without an oscilloscope.
If the console try to read the disk, but you only get whirring and clicking noise, ending up with a no disk, and if this happens with all disks then it is a lens problem.
Try first cleaning the Wii lens with a cleaner disk, that is the easiest thing to do.
If that does not work, the Wii must be opened to access the lens pickup directly, and clean the lens with Q-tips and isopropyl alcohol, or replace the lens pickup.
If the cleaner disk does not fix it, better to contact Nintendo calling the number listed on the user manual to see if they can cover the repair, or replace the Wii, before disassembling the console.
Hi Sky606, have you tried cleaning the game disk? Have you tried using other game disks in the wii to make sure it's not just one disk that is causing the problem. Do you have a Nintendo Wii CD / DVD Discs and Lens Auto Cleaning System ? If you don't you might want to purchase one and see if that helps, because your wii lens might need cleaning ! If all of that fails,your wii may need repairs, the lens that reads the CD/DVD could need adjustment or replacement ! One other small note,I always have a small external fan blowing on my wii when in use so that the wii wont over heat. Heat kills electronics ! I Hope this advice helps.
