There are series of problem
in wii which can be solved without much technical knowledge ........ your
problem belong to that so dont worry i will give you the link to download
the wii repair guide that will help you a lot Click
Here
This indicates a problem with the Wii console and it will need to be repaired...
Click here to download repair guide
I want to just make it clear to you, that you
can repair the following problems at home with a good repair guide. There is no
technical knowledge needed you simply do what you see on the step by step videos
or the paper guide.
SOURCE: wii will play gamecube games but not wii games
I heard something on youtube about that. It seems that the disc is hitting on the case so you would have to take it apart and fix it.
http://youtube.com/watch?v=1XKKLkqdZ34
SOURCE: wii game disc will not eject
you have three choices, 1. send it to get disc out, 2. take apart yourself or 3. keep pressing eject button till comes out, ( try laying it flat, on side and upside down).
http://www.wii-ftw.com/?page=disassembling_wii
SOURCE: Ejecting Wii disc while power is off
Your disc is stuck in Wii Console, It needs to eject manually. You might check out Wii Fix Guide,
that gives step by step information on Dis-Assembling with screenshots,
even a novice can fix the disc eject problem with the help of this DIY
Guide. It also gives information on fixing many Wii Related Problems,
so its a kind of Wii Problems Reference Fix Guide
