Try this. I have a similar problem and now have the LE code flashing. I saw this advice and am going to try the fix now.
You are barking up the wrong tree. Here is the real fix for the LE
problem.First disconnect all power ( power supply, circuit breaker,
wiring etc) to the machine. Disconnect all tubing to the machine (
drainage pipe and braided hose feed) Then you need to take out the
dishwasher, turn it over and then remove the large white sensor tray
that will expose the leakage sensor held on by 2 screws. Remove the
screws and dry up the sensor tips (4) with a dry towel and dry up the
tray all around as well. Replace the tray and re connect all tubing and
power. You're problem should be solved and you just saved yourself a
pile of money in service repair bill.
M.D.
The answer above does the trick, turn off the breaker, if you have enough drain hose just pull it out far enough to tilt the dishwasher face down on a large towel so not to scratch stainless steel. Take out the two screws as mentioned above to remove plate. Take out the two senser screws that hold sender to plate. Dry as mentioned above and you are all set. Thanks for sharing!
