SOURCE: How To Channge Frequency s in Motorola GP300
MOT GP 300 need RIB box and the software for the programming.
Give a google search for the home brewing of the RIB box.
Software is licensed and have to seek the support of a MOT dealer/ service.
SOURCE: GP300 frequency programing
Here is what you would need: RIB (radio interface box), HKN9857 programming cable and HVN9128 programming software. You are correct the software is only capable of running on a DOS box, such as a 286 or 386. The software mentioned is Motorola proprietary and is available to Authorized Motorola dealers by subscription only.
The book also shows a cloning cable HKN9755 as being available. Don't know anymore details on it.
Lastly, the cost of programming to your FCC assigned frequencies would be approx. $15 per radio, and less for cloning like models. It might be less expensive to have the radio programmed by a dealer. Just an FYI.
Best regards
SOURCE: Require Frequencies for CTCSS codes for Motorola GP 2000
check this link at page 21 or see below
CTCSS PRIVACY CODES FREQUENCY CHART (Hz)
Code Freq. Code Freq. Code Freq. Code Freq. Code Freq.
1 67.0 9 91.5 17 118.8 25 156.7 33 210.7
2 71.9 10 94.8 18 123.0 26 162.2 34 218.1
3 74.4 11 97.4 19 127.3 27 167.9 35 225.7
4 77.0 12 100.0 20 131.8 28 173.8 36 233.6
5 79.7 13 103.5 21 136.5 29 179.9 37 241.8
6 82.5 14 107.2 22 141.3 30 186.2 38 250.3
7 85.4 15 110.9 23 146.2 31 192.8
8 88.5 16 114.8 24 151.4 32 203.5
* Channel 8,9 and 10 are designated Canadian Marine Frequencies
* Channels 8~14 are low-power FRS license free channels
Note: Privacy codes can be programmed for use on Channels 1~22 only
Testimonial: "Thanks for the response. appreciated it. It is very useful."
SOURCE: I have 2 Motorola gp300 radios. My batteries are
If the radio will not power up with a known good battery the radio is in need of repair.
Best regards.
SOURCE: XU2100 (1 Channel) 2-Way Radio: How do I change frequency on a motorola xu2100...
Hello, I just purchased 3 of the discontinued XU2100 radio's, Can someone help me to change the frequency on them? My email address is [email protected]. Thank u for your time...
