I recommend you contact these guys https://www.bestbuy.com/site/electronics/geek-squad/pcmcat138100050018.c?id=pcmcat138100050018
SOURCE: win xp sp 2 and fujitsu siemens amilo pro v2030
here is the link for driver download it otherwise i will try another driver if it doesnt work with SP2 ok
http://webdownload.fujitsu-siemens.com/download/FileDownload/fileDownload.aspx?SoftwareGUID=F8D86EE3-5A24-4F8B-9FBC-3BA22CD6B7F2&FileFolder=Downloadfiles&FileTypeExtension=ZIP&FileNameClient=FSC_GemtekWMIB160GW_3100641_1003614.ZIP&FileSize=29309648&From=VXZ0Z2NvSGtuZ1ZxRHRxeXVndCAo
pls consider rating me FIXYA if i helped u
SOURCE: BIOS CMOS battery dead
You just have to go to the nearest computer store and purchase the battery you needed.
SOURCE: Wi-Fi
Press and hold fn and at the same time press the f2 button which has a wifi or 2 screens logo with a signal picture to sswitch wifi on.When it detects a wifi signal or says wifi detected just click the message and using your login and password connect to your network name.
SOURCE: keyboard replacement instructions
The keyboard removal process is very similar to many other laptop brands.
1. Remove screws securing the keyboard.
2. Remove keyboard bezel.
3. Unplug keyboard cable from the connector on the motherboard.
A word of caution. Be very careful with the connector on the motherboard when you unlock it If you accidentally break the connector, you’ll have to replace the whole motherboard.
You can even try this site http://mycapsules.com/disassembly/fujitsu-s2110/keyboard
or this site
http://www.amilo-forum.de/topic,1056,-Arbeitsspeicherwechsel-RAM-bei-Amilo-Pro-v2010.html
It is not your model but it will give you an idea.Just keep pressing "next"
Hope it helped.
SOURCE: How to change and upgrade the memory
on the bottom of the laptop is a square plate with 1 or 2 screws, when the laptop is off, remove those screws and you should see your laptop memory, gently expand the two thin metal clips on either side of the memory and it should pop up at an angle, gently remove it and replace with a larger capacty memory module.
