20 Most Recent Fujitsu Siemens SCENIC E600 Green PC (LKN:GBR-655111-041) PC Desktop Questions & Answers
No activity from computer. Fan runs for 2 seconds
chances are some capacitors have blown in the power supply. Replacing the power supply should solve the issue.
8/30/2011 6:04:09 AM • Fujitsu Siemens... • Answered on Aug 30, 2011
We have 5 PCs of
1/23/2011 7:10:32 PM • Fujitsu Siemens... • Answered on Jan 23, 2011
How to open fujitsu Siemens
Hi!
Check page 32 here: http://www.fixya.com/support/p340927-fujitsu_siemens_scenic_e600_green_pc_pc/manual-4363#
11/16/2010 10:10:17 AM • Fujitsu Siemens... • Answered on Nov 16, 2010
No ethernet controller
You can buy an ethernet controller that pligs right into any USB port.
11/6/2010 8:23:09 AM • Fujitsu Siemens... • Answered on Nov 06, 2010
I need lan driver for
Try www.fujitsu.com. There is a drivers download section there or you might try one of the other download sites like drivers.com or google the e600 and find a drivers download section. Happy hunting!
8/4/2010 1:16:42 PM • Fujitsu Siemens... • Answered on Aug 04, 2010
I need a diagram of the connection ports at the
oh, if you could send me a photo of how HIS computer looks like from behind, then it would be easier, since many of the outports are similar, and to a color blind person, some outputs may be mixed up with one another. more or less the name of the computer would probably be enough, but a photo will be faster
5/15/2010 11:46:48 PM • Fujitsu Siemens... • Answered on May 15, 2010
0answers
How do I remove the cover on a Fujitsu Siemens
Just remove the thumb screw and slide the casing going to the front.
1/23/2010 8:44:09 PM • Fujitsu Siemens... • Answered on Jan 23, 2010
Hi my problem is vga... hane any driver for this
Hi friend,
Thats means you are facing graphics problem with your system,use given below link and download the appropriate drivers,
http://www.drivershq.com/Drivers/Fujitsu-Siemens/Scenic/E600-(i865G)-TPM/24971/46137/46188/Drivers.aspx
Thanks,
1/18/2010 2:49:18 PM • Fujitsu Siemens... • Answered on Jan 18, 2010
Cant download software error 31 appearing
uninstall more burner software
11/3/2009 8:25:52 AM • Fujitsu Siemens... • Answered on Nov 03, 2009
My nec e6000 starts up ok fan spins lights work
You try to change the sources to see. Because your machine has been at the situation like this. If not you should still check the mainboard is not whether there is moisture. You should check the 4 pin 12v capacitor in jack on the main.
10/28/2009 6:46:27 AM • Fujitsu Siemens... • Answered on Oct 28, 2009
2answers
Hooked up a monitor and im not getting any
Assuming that your monitors are good, if nothing is shown on the monitor, that means it does not receive any signal from the computer (or CPU). When you bought it, did they show you the computer and monitor are in good working condition (that means Windows desk top screen comes up on the monitor if it is a PC). If everything was OK when they showed you, but when you took it home, it does not any more, then maybe something became loose while transportation.
Make sure that when you turn the computer on, you hear the fan on the power supply and inside the computer running, and there should be some lights in front of the computer . If you do not hear anything nor see any lights in front of the computer then that is the reason nothing comes up on monitor. If it is the case, you may want to remove the cover of the computer and physically inspect inside the computer to see if anything becomes loose while transportation.
Just some ideas for you to work on. Good luck!
8/29/2009 10:39:11 AM • Fujitsu Siemens... • Answered on Aug 29, 2009
2answers
Cover removal
Front fascia of case is part of cover. Press in side catches and at same time push with thumb on dvd drive - cover will slide forwards.
2/20/2008 11:33:26 AM • Fujitsu Siemens... • Answered on Feb 20, 2008
Keyboard unlock fn key lock
I have Fujitsu laptop some of the keys are lock how do I unlock them please
9/2/2022 8:51:09 PM • Fujitsu Siemens... • Answered on Sep 02, 2022
3answers
Beep code 1-3-3-1
It's the condensator near RAM. Exchange - it works.300 µF / 6,3 V
1/13/2019 5:34:28 PM • Fujitsu Siemens... • Answered on Jan 13, 2019
Atheros AR5007EG can't connect via WPA2 to WLAN on Windows XP
WPA2 is considered insecure and hacked years ago. You might try WPA, or get a different Adapter.
9/9/2018 6:04:58 PM • Fujitsu Siemens... • Answered on Sep 09, 2018
Fujitsu Siemens SCENIC E600 Green PC (LKN:GBR-655111-041) PC Desktop Logo
Popular Tags
26 questions posted
Top Fujitsu Siemens Computers & Internet Experts
Narseman
Rob Hill
Rob Hill
George Etukudo
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Fujitsu Siemens Computers & Internet
Most Popular Question
open fujitsu siemens
  • Computers & Internet
