Fujitsu Siemens AMILO Xi 1546 Notebook Logo
Question about Fujitsu Siemens AMILO Xi 1546 Notebook
Fujitsu siemens amilo xa2528 dont start, the fan works. Once today i could start after pressing F8 but after a while it froze and i restarted and now the same problem
  • Anonymous May 11, 2010
    No, but i found this and it´s exacly my problem: Mandatory BIOS update!!! Some Fujitsu Siemens Computers notebooks are experiencing long-term faults in their graphics displays. This is due to faulty graphics cards and chipsets. The problem can be remedied by replacing the graphics card or motherboard. During the warranty this repair is performed by us free-of-charge: The following AMILO Notebook systems may be affected: * AMILO Notebook Xi 1526 * AMILO Notebook Pi 1556 * AMILO Notebook Xa 1526 * AMILO Notebook Pa 1538 * AMILO Notebook Xa 2528 * AMILO Notebook Xa 2529 The following errors may occur: * Development of stripes on the display / garbage on the display * Display does not work at all * System does not boot For precautionary action you may update your Bios. The following updates are available, the others will follow, and we will update this page accordingly: AMILO Pi 1556 - BIOS Version: 1.26 AMILO Xi 1526 - BIOS Version: 1.26 AMILO Pa 1538 - BIOS Version: 1.1P AMILO Xa 1526 - BIOS Version: 1.1R AMILO Xa 2528 / Xa 2529 - BIOS Version: 1.0R If your system doesn`t show one or more of these symptoms we strongly recommend to update your system with the latest BIOS version available for download on our support pages. If your system is showing one or more of the mentioned failure pictures please contact your local service helpdesk.http://support.fujitsu-siemens.com/com/ ... pdesk.html ENTER SERIAL-/IDENTNUMBER Step 1: Identify your notebook series and product number and make sure that your notebook may be infected by the defective graphic cards / chipsets. Check the back of your notebook where you can find the needed information: Step 2: Identify your current BIOS version: 1. Press button to start system 2. As soon as the FSC logo appears please press button "F2" 3. After entering the BIOS menu press right arrow button to get to Info menu. Here you can check current BIOS version. 4. To exit BIOS please press "F10" and Enter Step 3: How to download and install the new BIOS 1. Before starting the BIOS update please ensure that the power supply is plugged 2. Then go to FSC download page and select the correct product. 3. Select your operating system and choose Flash-BIOS 4. Select BIOS-Windows-Flash and click on button "Download" 5. After accepting the license conditions you can download by pressing the button "Download software" 6. Please save the program to an extra folder or desktop 7. Go to that folder or desktop and start the program by double click 8. Follow all prompts and restart your notebook when requested. 9. Don`t turn off your notebook until requested to do so. Frequently asked questions Q: I am experiencing one of the symptoms, but my product is not listed. Is there any possibility that my notebook PC has the same issue? A: To date, the only products affected are listed in the beginning of this document. If you continue to experience symptoms with your notebook please contact your Fujitsu Siemens Computers support center. Q: If my notebook is functioning properly will I experience these symptoms in the future? A: Your notebook may experience some of the symptoms listed at a future date. However, certain notebooks may not display these symptoms at all. Q: Can I continue to use my notebook if I do not experience a failure? A: Absolutely. If your notebook is not experiencing any of the symptoms you can continue using your notebook. Q: What is the benefit gained from updating to this new system BIOS? A: The BIOS updates the fan control algorithm of the system to reduce the likelihood of future system issues. This BIOS release is preventative in nature. Q: What kind of issues will I experience if I do not update with this new system BIOS? A: You may not experience any issues. But to avoid later problems Fujitsu Siemens Computers recommends to do the update. Q: What should I do if my notebook is already experiencing symptoms? A: The problem can be remedied by replacing the graphics card. During the warranty this repair is performed by us free-of-charge and usually takes 3 to 4 weeks. Q: How long will my repair take? A: It goes without saying that our aim is to keep the repair times as short as possible. Delays may occur on account of the reduced availability of the components. Q: Will I be getting a replacement device? A: Generally we don�t offer replacement devices when repair is possible Q: Why can`t I use a graphics chip from another manufacturer? A: The graphics cards from other suppliers are incompatible with the computer. Graphics cards are always bound to the respective device on a 1:1 basis. This is why you have to use the same graphic card that was originally installed Q: To what extent is the repair likely to be successful? A: The new graphics card eliminates the problem described. Q: Do you assume that future products from Fujitsu Siemens Computers will also be affected by this error. A: No, we do not. The fault lies with the graphics card which is no longer being integrated in the notebooks.
Anonymous
    New Friend:
Hi, I have had a 1556 lying around for about 8 months that started playing up with the graphics. Couldn't buy a card back then for less than a couple of hundred so was going to strip it down and sell on ebay for spares. Never got round to it and was looking on ebay and found a card for £59.99 took a bit of a risk as it was an 8600M 'GT' and no one knew if it would work and said it needed a 'GS'. Took the chance and with a beta driver downloaded from Nvidia site glad to inform it works perfectly. Hopefully this later card has had the gluing problem sorted but i am going to do a bios upgrade or do the temperature fiddle to get the fan on sooner and faster. Must say the computer is one of the best I have had for graphics quality and speed. Maybe I will sell it on though while its a runner as it looks good machine. `
Posted on Jan 20, 2010
2answers
I have got a problem,when i wanna run the wireless on laptop,it doesnt allow me to connect,it keeps saying "turn on your wireless compability" and it says that you can do this by switching on a...
Here the list of FUJTISU SIEMENS-AMILO models and where the wireless switch is located. Hope this will helps. Check what family your laptop belongs to then turn on the wireless swith using the list below:
Fujitsu Siemens Amilo A Series ---- Button above the keyboard on top right
Fujitsu Siemens Amilo D Series ---- Button above the keyboard on top right
Fujitsu Siemens Amilo K Series ---- Not Wireless
Fujitsu Siemens Amilo L/EL Series ---- Fn / F1 to turn on/off
Fujitsu Siemens Amilo La Series ---- Fn / F2 to turn on / off
Fujitsu Siemens Amilo Li Series ---- Easy launch button (one of 3) on top of keyboard
Thanks for using Fixya.
Screen stays blank after start up. Grafic card?
take battery out then get rid of dust then restart it if still doesn't start make sure adaptor works correctly, if problem is still there its a computer error/bug
My siemens amilo d7830 the screen is showing blank. any idea please
Press
Fn+F8 then it might be working.
If that does not work then try;
Fn+ CRT/LCD
9helpful
2answers
Fujitsu Siemens Amilo Li 2727 how do i take it back to factory settings
Hi there.
To factory restore a Amilo 2727, restart the laptop and press F8 as it starts up. It will bring you to a sub menu with safe mode etc, in that list you will see factory restore, choose that option and just follow the on-screen instructions.
Good luck with the restore and thanks for choosing FixYa!!
Fujitsu siemens amilo L1300 LAPTOP wont load up
sounds life the start up files have been corupted you may need to reinstall windows. the only thing is it will delete and data you have on the labtop. if you dont mind about that reinstall windows of the reinstalltion cd.
2helpful
2answers
Wireless connection
You did not state which laptop model you have. Here is a list of the most common key strokes or switches:
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Amilo pro 2030v faan
We did not find any results for Fujitsu > AMILO Pro V1000 (FAP:GBR-147150-H01 ) needing a fan for my laptop computer. Other searches you may want to try: Related searches Click on the Link above, Good Luck.........Please dont for get to Vote, Thank You.
Ref fujitsu siemens amilo pro v2040 problen
You will then need to repair windows, ensure your cd drive is set as first boot device in bios and insert windows cd and press 'R' for repair instead of install when all the setup files have loaded.
Fujitsu siemens amilo pro v200 problem!
this could be a corrupt usb controller or web cam driver; but before we get too deep when it is booting up press F8 and you will get a menu, one of which will say, start windows with 'last known good configuration', highlight line the press enter for a restart. If no luck with boot up come back.
Top Fujitsu Siemens Computers & Internet Experts
Narseman
Rob Hill
Rob Hill
George Etukudo
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
