Our linksys wireless g router just stopped working.
In order to try to recover your router, the first thing to do is to try to reset the router to factory defaults. To do this:
1) Power down all computers, the router, and the modem, and unplug them from the wall.
2) Disconnect all wires from the router.
3) Power up the router and allow it to fully boot (1-2 minutes).
4) Press and hold the reset button for 30 seconds, then release it, then let the router reset and reboot (2-3 minutes).
5) Power down the router.
6) Connect one computer by wire to port 1 on the router (NOT to the internet port).
7) Power up the router and allow it to fully boot (1-2 minutes).
8) Power up the computer (if the computer has a wireless card, make sure it is off).
9)
Try to ping the router. To do this, click the "Start" button > All
Programs > Accessories > Command Prompt. A black DOS box will
appear. Enter the following: "ping 192.168.1.1" (no quotes), and hit
the Enter key. You will see 3 or 4 lines that start either with "Reply
from ... " or "Request timed out." If you see "Reply from ...", your
computer has found your router.
10) Open your browser and
point it to 192.168.1.1. This will take you to your router's login
page. Leave the user name blank, then in the password field, enter
"admin" (with no quotes). This will take you to your router setup
page. Note the version number of your firmware (usually listed near
upper right corner of screen). Exit your browser.
If
you get this far without problems, try the setup disk, and see if you
can get your router set up and working. When you get to the password
prompt in setup, be sure to leave the user name blank.If
this does not fix your problem, then report back with your results,
including any error messages, and the firmware version number if you
have it. Also report back the status of your router lights.
