Washing Machines Logo
Anonymous Posted on Nov 17, 2010
Won't agitate - KitchenAid Washing Machines
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 23, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
162
Points
My kitchenaid superba washing machine's agitator is making loud noises and is just twirling the clothes in one direction. It seems to be loose or something. The clothes spin fine on the spin cycle. Any thoughts?
Figidaire FTF630as0 won't agitate. The door locks and water drains but won't agitate or spin
Hello Tina Kaha - Often when a unit does not spin, it is because the unit cannot properly drain and dispose of the water and detergent solution. Does the unit make a humming noise? If so, the drainage hose/pump may be clogged and needs to be cleaned. If not, the washer may possibly be experiencing an issue with the door lock assembly, faulty pump, timer or control board not communicating correctly. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair the unit.
Kenmore washer model #111092581200 won't stop filling and won't agitate
Please recheck that model number. It is coming up as a microwave.
My candy GOFS262 washing machine is filling the drum to the top with water on every cycle but doing nothing else after that, the clothes jst sit there in the water, I've left it to see if something...
see this causes and fix it. God bless you
Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and transmission.
Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
Drive Motor If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it.
Stator Assembly If the washer won't spin or agitate the stator assembly might be burned out. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't spin or agitate the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin or agitate the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
1helpful
My roper top load washer model rtw4440vq fills with water but wont wash, spin or drain
Washing machine won't fill. i filled it by hand with water, it won't agitate either, only spins.
The inlet solenoid is probably bad. And it won't agitate unless it fills and stops filling automatically.
What should i look for on my whirlpool washer if it hums but won't spin, agitate, or drain?
The motor may be shot if it is getting current and won't operate the washer.
33helpful
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Top KitchenAid Washing Machines Experts
Paul Bade
ADMIN Andrew
ADMIN Andrew
Are you a KitchenAid Washing Machine Expert? Answer questions, earn points and help others
