Belkin (F5D5231-4) Router Logo
Posted on Nov 15, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My belkin wont keep connection - Belkin (F5D5231-4) Router
Donivan Wise
Level 2:
Sergeant:
  • Expert 254 Answers
  • Posted on Nov 16, 2010
Donivan  Wise
Expert
Level 2:
Sergeant:
Answers
254
Questions
0
Helped
65800
Points
574
1. Powercycle your equipment (unplug the power to your router and your modem)
2. Wait 15 seconds then plug equipment back in.
3.If your Modem runs off signal from a tower try and get more signal simply by moving modem closer to a window.
4.Check your connections to the modem and to the router, ensure the wires are plugged all the way in.
5.Using your wireless signal from your computer pc or laptop ensure you have sufficient signal you may have to move closer to the router, once in a while you will be to far from your router to have a good connection.
6. Make sure the ventilation slots on modem and router are not blocked.
7.Check to see how far your modem is away from any electrical equipment your modem should be away at least 3 feet away.
8. If you are able to keep connection directly plugged into your modem from your computer most likely there is an issue with the router, In this case you can always reset your router there may be a configuration error in your router, To reset simply press and hold reset button on the back of the router for approximately 15 seconds or until router restarts, Caution by resetting your router will reset back to factory default and your router will be unsecure once again.
9. When your are disconnected from the internet make sure that the Connection itself isnt still connected if your connection itself is connected and you are unable to get online you may need to renew your ip address. usually your ip address automatically renew's once the router and modem have been powercycled (unplugged and plugged back in) however you may need to manually renew your ip.
10.Windows Xp: Start/Run/CMD and press ok
A.Type ipconfig /release
B.Type ipconfig /renew
Windows Vista/7 Start/All Programs/Accessories/Right click on command prompt and hit run as administrator.
B.Type ipconfig /renew then restart your computer
If you are a Mac user:Here is a link to show you how to renew http://support.apple.com/kb/TS1920 If your continue to get disconnected contact your ISP (Internet Service Provider) Check and ensure that it is not an issue on there end
Level 3:
  • Belkin Master 7,733 Answers
  • Posted on Nov 15, 2010
Belkin Master
Level 3:
Answers
7733
Questions
0
Helped
1865105
Points
21487
Are all computers connected to the router affected?
If so, try this first:
  1. Unplug the power to the cable / DSL modem
  2. Connect the power to the router.
  3. Connect a computer to one of the LAN ports of the router.
  4. Restart your computer.
  5. Restore the router to factory defaults. Note: This will remove all previously configured settings.
  6. Once the router has gone through the restore it will then begin the reboot. When the reboot completes plug the power back into your modem.
This addresses a common scenario where the router has been connected to the Internet for an extended period and holds an IP address (DHCP lease) for a longer period of time than your Internet Service Provider (ISP) allows.
This is normal and does not indicate any issue with your Belkin router or ISP.
If the router is located where you cannot easily unplug it, you can restart it using the router's web-based interface. If your DHCP lease time seems to be extremely short, contact your ISP to see if there are other issues on the network.
In certain network scenarios, it may be helpful to turn off all the equipment on your network, and then turn it all back on. Leaving some devices unplugged for up to five minutes can also help. Try unplugging the router, any switches, and any cable or DSL modems. Shut down connected computers. Plug in the cable or DSL modem first.
Plug in the Belkin router second, and wait for the lights to cycle through the startup routine. This prevents another device from taking the DHCP lease. Lastly, start up your computer.
Are just wireless clients affected?
If so, focus on factors that affect wireless clients, such as:
  • Network selection and security
  • Hardware access control
  • Client TCP/IP settings
  • Signal strength
  • Sources of interference
Are just wired clients affected?
If so, check your network adapter settings. Check all cable routing, connections, and power supplies.
Can you connect to the Internet directly?
Set up a computer to connect to the Internet directly, without the router.
If you cannot connect to the Internet without the router, please contact your Internet Service Provider for assistance.
Check your signal strength
You may lose your wireless connection if you go beyond the range of the router, or if there is an obstacle between your computer and the router that blocks wireless signals. You can check signal strength by opening your wireless adapter's interface.
Here what is happen my sister law had a Belkin router that went bad she got a norther Belkin router not the same one but it a Belkin here what going on she try to hook it up and she Chang to use broadband...
The ISP modem connects to the wireless routers main port. Then connect the PC to any other port on the router.
Use the default wireless settings that Belkin provides. There is a small tag under the unit with the default information. Or, use custom settings in the web admin.
I cant keep an internet connection with my router..i try unplugging it multiple times a day..and then it finally connects and a few minutes later when i first get on a site it shuts down again and wont...
Its seems to be a configuration issue
Open Web broswer and type >192.168.2.1 You will get Belkin Router Setup page Towards the left side Under Utilities you can find RESTORE FACTORY DEFAULTS( CLICK ON IT) it will ask for a password, By default no password so leave the Box blank and click submit Click OK for all the disclaimers
Once you get the Belkin Router Setup page back
Toward left side you can find CONNECTION TYPE( Click on it) Select DYNAMIC and click NEXT For Hostname you can leave it Blank Then click on Apply changes
Toward left side you can find MAC ADDRESS( Click on it)
Then click on CLONE and Click APPLY CHANGES
Hope that will fix the issue
Or else you can always call belkin support, they will assist with the steps
2answers
My wireless light on my router keep blinking red
Integrated Router/Firewall/VPN -40 to 85C, Immunity to EMI
3helpful
New Belkin router wont connect to internet.
your user name and password have been entered incorrectly, they are case sensitive and must be exact. Make sure your ADSL settings are set at 0/38 (you'll see where)
How to connect new apple macbook to belkin G Plus
You do not need a compatible driver for use with the Mac. Reset the Belkin to default, then tuen your Mac on. The airport should see the wireless network and connect
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Belkin Wireless G+ nic can't keep internet connection
check if ur able to gonline with the cable connection. checked if the wireless key entered is correct
try to update the software
go to start-computer-right click-properties-devicemanager-network adapter- rightclick on the broadcom -update driver from the net with the cable connection and this will probably resolve the issue
Cannot connect belkin wireless adapter to my xbox 360 thru my pc
every computer has an ip adress you might have to go to your internet setting and find some thing that says some thing like... internet adress hook up hopefully you keep files on your computer becuase with out your ip adress you might not be able to hook up its sorta like a combination hope it helpes:)
I have netgear sky router belkin wireless g usb adapter sinal strength is excellent but it wont connect keeps saying acquiring network adress what can i do it has worked in the past and oblige
go to the router setting by logging in as a administrator then check the wireless setup access, then add your WIRELESS DEVICE 12 digital MAC address then apply it and logout
How to reconnect my belkin router
Need clarification:
1. Is this a wireless connection.
2. Broadband Internet? Your router is the only way to get to your Broadband connection?
3. What operating system do you have.
4. Did you ever have a connection in the past or is this a new router on your network?
Top Belkin Computers & Internet Experts
ExpressFiX
ExpressFiX
Alexander
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
