Hi
A WEP key is a security code used on some Wi-Fi networks.A WEP key is a sequence of hexadecimal digits. These digits include the numbers 0-9 and the letters A-F.
The length of a WEP key depends on the type of WEP security (called "encryption") utilized:
WEP keys are chosen by a network administrator, it would have been provided by the Internet Service providers, Hence it can't be as what you stated.
Type
the following text in the user name and password fields: "admin".
Go
to the Basic Settings
menu option tab on the top navigation bar and wait for the menu to appear.
Click the
Wireless Security menu option in the drop down menu.
Click
to select Enable Wireless Security.
Click
to select either WEP or WPA in the Network Authentication list.
Select
hexadecimal or ASCII characters as the Key Format. You can use either as
a string of hexadecimal digits (characters 0 through 9 and A through F ) or as
ASCII characters (any key on the keyboard).
Select
an encryption level from the Key Length list.
Enter
four different keys in the Key1, Key2, Key3, and Key4
fields to store on your router. For 40(64)-bit encryption, enter a 5-character
(or 10 hexadecimal digits) WEP key. For 104(128)-bit encryption, enter a 13-character
(or 26 hexadecimal digits) WEP key.
Select
only one key out of the four keys as the Default Key for encryption.
Click
the NEXT button, and then click Save and Restart to apply the
changes.
Set
up WEP encryption on your wireless clients. Refer to the documentation that
accompanied your wireless clients, or your wireless clients' on-line help
systems, for information on how to set up WEP encryption.
Enter
your pre-shared key. This key must match the key that is used by each wireless
client computer associated to your router.
Choose
a key format. This can be hexadecimal digits (0-9 and A-F) or ASCII characters
WPA Group Rekey Interval specifies how often the key "rotates" or changes.
WPA
Encryption allows you to select one of two possible encryption methods-TKIP
and AES. Choose one that your wireless clients support.
Click
changes.
Set
up the WPA on your wireless clients. Refer to the documentation that
system, for information on how to setup WPA.
