May also be a T-CON board problem, they are known to go bad on this model.
Here's something that could possibly help:
http://www.coppelltvrepair.com/p/828/repair-service-for-samsung-ln37a450c1dxza-t-con-board-causing-inverse-colors-or-other-image-deformations
Samsung has had some issues with stands that are screwed in to panel have cause video issues from pressure to panel. Some times removing the screws from base can relieve this problem. From what you are discribing though i would think that you probably have a bad main board. You definitely need a technician to check this out.
SOURCE: My new Samsung LCD Tv
Heres a web site i found on samsung support, i had the same problem
http://ars.samsung.com/customer/usa/jsp/faqs/faqs_view.jsp?SITE_ID=1&PG_ID=3&PROD_SUB_ID=41&PROD_ID=154&AT_ID=128580
SOURCE: Samsung 46
It sounds like T-CON board (mounted under the metal shield mid top section of the screen) problem. You can try cooling it with electronicn freeze spray for electronics torubleshooting to see if the problem goes away.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
