20 Most Recent Samsung PCL545R 54" Rear Projection Television Questions & Answers
Convergence on edges will not fix.
https://youtu.be/esk4nYZKFcg
3/3/2018 2:18:47 AM • Samsung PCL545R... • Answered on Mar 03, 2018
0answers
Have Blu ray player with Wi-Fi and need to connect to this TV
If you can't find a special wire for that you may need a box that converts video from and to whatever video wires you want http://dx.com/p/component-video-ypbpr-to-hdmi-converter-box-with-spdif-audio-input-29772
11/25/2013 5:14:01 PM • Samsung PCL545R... • Answered on Nov 25, 2013
Tv cuts off and won't come back on unless we use a blow dryer to heat up the bulbs in the back of tv
HelloWill you please give me some more details about the fault with your Samsung TV? Will it stop working while going on; of will it won't switch ON on cold coditions. Please clarify more. OK.
11/7/2011 3:19:48 PM • Samsung PCL545R... • Answered on Nov 07, 2011
Ghost blue line with a
I'm sorry that the TV is displaying ghost blue line with a curve in the screen. Please follow the troubleshooting steps and check the operation:
Please make sure that the connections are secure and proper.
Try connecting a different video source like DVD player or VCR and check the operation.
If it works with another device, the issue might be with the input device currently.
Also try connecting the device to a different port in the TV if no other devices are available.
If the issue persists, try with a different cable.
Perform a power resetting and check the operation. To perform the power resetting, unplug the TV from wall outlet for more than 2 minutes and then reconnect it.
If the issue persists, after all above troubleshooting steps, service may be required. You can click hear to setup a service for the TV.
Thanks for understanding. Please let me know if you require any clarifications/additional help.
9/6/2011 2:21:42 AM • Samsung PCL545R... • Answered on Sep 06, 2011
2answers
I was told to adjust the convergance manualy and i
Convergence output IC's need replacment ,there is two of them one for Vertical and another one for horizontal deflection.One of them is burnt but my suggestion is to replaced both.They are mounted on big hetasink and easy to replaced
8/23/2011 2:53:45 AM • Samsung PCL545R... • Answered on Aug 23, 2011
Tv gets light blueand stays
Behind the screen, there are three color tubes: Red Green and Blue.
Unfortunately, rear projection screens often have these problems and the tubes do go out after extended use.
Take the television to a TV Repair shop to have this fixed. But in the long run, this may end up costing you a lot more than if you would purchase a new TV. The light tubes are fairly expensive.
6/3/2011 5:11:27 PM • Samsung PCL545R... • Answered on Jun 03, 2011
0answers
Curved red lines on the screen and the picture is distorted
This is a convergence problem that can be either poor solder connections on the convergence ICs or defective ICs. If you can solder you can fix this yourself. Update this if you wish to attempt the repair and I'll supply additional details and instructions.
Dan
12/28/2010 1:32:52 AM • Samsung PCL545R... • Answered on Dec 28, 2010
2answers
Samsung PCL545R Online or downloadable manual
Please click the link below to download the manual for Samsung PCL545:
Samsung PCL545R Manual
Thank you
9/28/2010 5:13:41 AM • Samsung PCL545R... • Answered on Sep 28, 2010
I need to replace the
all2brite,
The best place for quality lamps and good prices is http://www.encompass.com . They have options to also allow you to just purchash the lamp, not the entire module. This could save you 30 percent. I would not go this route unless you are good with tools and can think things through.
Either way I have a tip at http://www.fixya.com/support/r4168009-change_lamp_in_dlp_projection_tv which explains the process and will help you with the repair.
Thanks for using FixYa and for the great rating.
hardrocko
9/27/2010 2:41:07 AM • Samsung PCL545R... • Answered on Sep 27, 2010
Pcl542r, powers up pip image works menu images ok,
Very strange, and if you disable PIP altogether, you get no image? That would only mean to me that your primary "image" is using the incorrect input.... switch the inputs on the primary image by using the INPUT or SOURCE button on your remote. It should be something similar to that. You should be able to cycle through the inputs on the TV to get a picture from all the different inputs on the back of the TV....
Thanks
Tim
9/21/2010 2:16:51 AM • Samsung PCL545R... • Answered on Sep 21, 2010
0answers
Shadows around the images
If it is 3d looking or anything like the attached photos it is convergence problem. I can tell if it is what is involved to fix.
I am here to help.
If photos or information given helped you rate this solution as very helpful as I do this here for free.
SD TECH
8/19/2010 2:05:17 AM • Samsung PCL545R... • Answered on Aug 19, 2010
Samsung PCL545R 54 in. Rear Projection Television
Ur tv have a problems known as a convergence problems,it dead.The tv covergence board must have it 2 STK Convergence ICS and some or all resistors be rreplaced to solved the convergence problems.The shop will cost u $300-350 for parts and labors.
7/5/2010 8:35:24 PM • Samsung PCL545R... • Answered on Jul 05, 2010
The right side of the TV has shadows/distorted images and colors
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
7/3/2010 6:39:08 AM • Samsung PCL545R... • Answered on Jul 03, 2010
How do i fix the tv if there is a red line going
this is a convergence fault and requires repairs to the sustain boards. est cost about $300
Please rate my hyelp++++Thanks for using FIXYA
7/1/2010 8:08:31 AM • Samsung PCL545R... • Answered on Jul 01, 2010
Samsung PCL545R 54" Rear Projection Television Logo
Popular Tags
96 questions posted
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
View Most Popular
  • Samsung Televison & Video
Most Popular Question
tv gets light blueand stays
  • Televison & Video
