SOURCE: ac power cord for HP vf51 flat panel monitor
Good Day Tricia,
I had to pull up you owner's manual to get the spec's on your cord, so if you need the manual follow this link:
http://h10032.www1.hp.com/ctg/Manual/bph08231.pdf
Anyway after reading the spec's you need an AC-DC power supply that outputs 12volts at 3.3amps. What makes this difficult to find is the 3.3amps, most aftermarket power supply only go up to 2amps. So what's next? Well you can order directly through HP at this link:
http://partsurfer.hp.com/cgi-bin/spi/main?sel_flg=partlist&model=P4824A&HP_model=&modname=HP+vf51+15-inch+LCD+flat+panel+display&template=main&plist_sval=Power+Cord&plist_styp=subcat&dealer_id=&callingsite=&strsrch=&keysel=Power+Cord&catsel=%3F
If you do this make sure get part 8121-0740 if you live in the states, or part 8121-0731 if you live in europe.
The only other suggestion I can give is to bring the monitor into a radioshack and see if they have a 12VDC 3.3AMP (you can get a universal with higher amperage if needed, the monitor will only draw the 3.3 it needs even if it is supplied more) and the reason I say bring it in is so they can match the size of the plug that goes into the monitor, as there are about 20 diffrent diameters's. Again the problem you may have is finding one with a high enouge amperage.
I hope this helps
Good Luck
SOURCE: No power to monitors, but blinking led on ac adapters.
Hi...there,
Try replaced with a new AC Adapter. If it still the same...then you got a busted backlight inverter. To order a new AC Adapter go to this site @ www.3rd-rocks.com click on lcd parts. have a nice day!
SOURCE: Iiyama Prolite 434S monitor is too dark
Dim or dark display can be caused by a faulty inverter board or faulty CCFL lamp. The inverter supplies high voltage to the CCFL lamp, the CCFL lamp is a miniture fluro tube and these dim with age.
Check out LCD Parts for service, parts and DIY info - click on this link to their WEB site. :-
www.lcdparts.net
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
