I suggest you save that web page address to your Favorites / Bookmarks.
Using the conversions calculator for milliliters to U.S. fluid ounces, this is the result:
50 ml = 1.690701 U.S. fluid ounces
This is the result for U.K. fluid ounces:
50 ml = 1.759754 U.K. fluid ounces
I assume your question has to do with liquid perfume.
The conversion is from inch pounds to Newton Meters
The factor: 1 Lb-Ft = 1.35582 Nm.
The direct quote: boltscience.com
Torque is a measure of how much twisting is applied to a fastener. The units used to measure torque are in the form of force times length.
The metric (SI) unit of torque is the newton metre (Nm). In inch units, torque is usually measured as Lb-Ft (pounds feet) or Lb-In (pounds inch). The Torque Converter Calculator will allow you to convert Nm to Lb-Ft or Lb-In or vice-versa. The calculator uses the conversion 1 Lb-Ft = 1.35582 Nm.
If you are referring to the metric units system, cm(centmeter) is the units used in measurement of length and gm(gram) is the unit measurement for mass/weight. You cannot convert cm to gm because they are different entities & properties.
1. You can use google for that.
Ex: you want to transform 10 m into an x unit. just type 10 m to x and you'll get the result.
2. You can use this website: http://www.digitaldutch.com/unitconverter/
First close all open windows/projects in 3D Home Architect Deluxe, but do not close the program.
Then a new set of taskbar/ menu items appear, click on File and then on "change units".
Sorry this is so late, but it took me a few hours to figure this out.
Click the screen to access main menu this should bring up the ability to click change preferences and then in that menu you should be able to scroll through and find the option to change from feet and inches to metric.
